Learning how - WELDING
/ Learning how - WELDING #21
hey patrick,
ive been weldin for 17 yrs and like it. i have the lincoln sp125 mig and the ability to use 110v is great. next came the miller thunderbolt 225v ac/dc stick welder. after i really got into doing side stuff i got a miller bobcat, then, after full addiction to portable welding i got the trailer for the bobcat and the wire feeder and use flux cored. i have a speed glass helmet at work that i bring home when i weld. im spoiled by this helmet. it is great for a beginner who has bad habits of moving when flipping down the lid and also when you have those hard to reach spots it keeps you from hiking thru the cave with a flashlite, ya know, like sparking your way to the weld area. save the few bucks and buy one. what kind of flux cored do you use? i use lincoln innersheild nr-211-mp .035 and like it very much. the little sp125 has welded alot of tree nursery stuff even in the larger ranges without any failures. now it is in the bobcat wire feeder and pours out like a chaulk gun. it also runs alot nicer in the bigger unit. just point, aim, and pull the trigger. the slag scraps off with yer fingernail.
rich
/ Learning how - WELDING #22
I took about 4 months of classes (3 nights a week) to learn to weld about a year ago at a local vocational school. I really learned alot. Like others said, the instructor was a retired welder, and he was a storehouse of information.
One of the things he told us was that we needed to be good at stick welding. Other welding techniques are easier to master (mig and tig in particular), but you can produce welds that look pretty, but have no real strength.
His theory was that if you could become proficient at stick welding, you would do the other types without a problem.
Nice thing about the class too was the ability to try out different equipment. I was able to torch cut, weld and braze, mig weld, tig weld, plasma cut and use the metal forming equipment.
Go take the class, it is REALLY worth the time. Mine cost $3.50 an hour and you can burn alot of rods in an hour /w3tcompact/icons/smile.gif
/ Learning how - WELDING #23
I also took a course at a vocational school - it was a blast. Nothing quite like quietly welding your neighbours project to the bench when he's out at the rest-room. I miss the practical joking that used to happen when I was more 'hands-on'.
The other thing we learned was that grease and welding don't mix well. A bit like eggs in the microwave, but will put you in hospital - don't try that one at home.
Another don't try at home - had a local guy lose an arm around 10 years ago in a welding accident. He was trying to repair a cracked rim on a heavy earth-mover at a local quarry. The tire exploded and a large chunk of rubber just about ripped his arm from his socket. Don't try that one either!!!
/ Learning how - WELDING #24
Larry,
I'm like you. Want to start welding stuff around the homestead. Probably will take a course at the local JC. That said, if I were to get one welding outfit, what would I get? Mig? Tig? Arc? Gas? Friction stir? (put that last one in there to see if anyone is paying attention /w3tcompact/icons/smile.gif)
The GlueGuy
/ Learning how - WELDING #25
GlueGuy,
I'm running a little Century wire welder from Quality Farm. It has mig capability but so far all I've needed is the flux core. Besides, I'm afraid if I ever try with gas I might like it too much and then I'd have to drag the bottles around. The Century is small enough that it fits right on the floor on the passenger side of my truck and is easy to lift in and out. It's 110 voltage, so I can run it off my generator for field repairs. (The generator is a little harder to load). A spool of wire is about $15.00 at Quality, and I keep several spools available. I've welded everything from sheet metal on car bodies to 1/4 plate with it. The only thing I wish is I had spent the extra $100.00 and bought one step better machine. I have infinitely variable wire speed, but only 4 heat settings. It can get a little tricky matching wire speed to heat and getting that to set up for the thickness of steel. Hobart also makes a great machine, but they're a little bit more expensive.
Mig or wire is probably the easiest to learn. I just asked a friend who is a welder to teach me and he got me going. Then practice, practice, practice. My biggest problem is going too fast and losing the arc. Remember it's supposed to sound like bacon and eggs frying. If it pops, you lost your arc.
The advantage to arc and gas is you can get farther from the welder because you can extend your cable or hose. You're pretty much stuck with a mig at however long the factory hose is. (Unless someone has found something I haven't).
When you buy, look at the DUTY cycle. The higher the rating, the longer you can weld. With mine, I can set to low power and weld longer than I really want or need to. On High power, I've got under 60 seconds to finish whatever and let the welder cool back down.
Hope this helps.
SHF
PS, Friction stir sounds like something you'd do on plastic. /w3tcompact/icons/laugh.gif
/ Learning how - WELDING #26
A small MIG setup does look like the economical/practical compromise. I think I would get something in the 175-200 amp range. I'm not too concerned about 110 vs. 220 issues as I have a 50 amp 220 outlet in the garage (where most of the welding would probably happen), and my generator also has a 50 amp 220 outlet (but the sucker weighs 350 lbs. so is not exactly "portable" even though it has wheels /w3tcompact/icons/tongue.gif).
The big question is: OK, so a decent TIG is going to cost (at least) twice as much as a decent MIG. What am I really losing if I choose a MIG instead of a TIG?
The GlueGuy
/ Learning how - WELDING #27
I would go with the mig hands down for general home use. Tig is the hardest to do in my opinion. Also need shielding gas and a real nice machine as well. So if your going to go to that expense in time you will be able to weld just about any metal with the correct shielding gas and lots and lots of practice.
Tig is sort of like gas welding only twice as hard. I've just started messing around with it.
If you go with a fancy ac/dc machine you can get a wire spool add on and be able to mig as well. All in how much pocket jingle you've got to spend.
Gordon
/ Learning how - WELDING #28
Smith, don't know where you are located? I have talked to many kids who have in the more rural settings had high remarks on courses just for the farm. 4H and Future Farmers of America type clubs for the kids. If that is all your needs, look for that type of schooling. I keep an older AC stick machine and gas bottles for cutting and heat. I've done structural pipe but no stainless in the Nuclear field. Don't choose to. If I was still hammering on the old Ford Model A's, I'd go for the mig. The little bit of stainless or aluminum I'll have done at the shop. Go for the basic's. It's a good talent to have.
Like Red Green says, "If the lady's don't find you handsome, let them find you handy". /w3tcompact/icons/laugh.gif
"What is a weed? A plant whose virtues have not yet been discovered."
Ralph Waldo Emerson (1803-1882)
/ Learning how - WELDING #29
GlueGuy,
Don't know for sure, don't TIG weld. I did buy a book about it, though and it looked like TIG would be harder to learn, as I recall, you're back to using a stick that has to be replaced periodically. With MIG, you just press the button and the wire comes out until you use up the 3 pound spool.
Only one caution about wire. BE CAREFUL about the back side of your project. Nothing can warm up your day worse than a couple inches of hot wire shooting out the back side of a joint and contacting something you'd like to keep! Generally, I've only had that problem when filling holes in sheet metal. But it makes the back of the project look like a porcupine. You're supposed to be able to clamp a piece of copper stock to the backside and weld away. The wire isn't supposed to stick to copper. But I've never had a scrap piece of copper stock laying around to try it. /w3tcompact/icons/wink.gif
SHF
/ Learning how - WELDING #30
Hawgee,
[[[Smith, don't know where you are located?]]]
I think you'd say "I'm just down the range from you".
I was LHSmith in my larval form /w3tcompact/icons/laugh.gif ...hatched out as "JOR_EL" when I registered, having finally brought home my new tractor "SUPERBABY" /w3tcompact/icons/wink.gif
I found a (very good, I think /w3tcompact/icons/tongue.gif ) book , ...WELDER'S HANDBOOK, by Richard Fink (HPBooks-1264) and have been trying hard to absorb it.
I have a basic aircraft size oxy/acet set, and the Dillon low pressure torch.(had both for some time, used them next to not-at-all)
I'll probably end up with a mig setup,...tig sounds great, but maybe too many $$ for the use I'd give it. Got a lot more to learn, ...keepin'-on a'readin' /w3tcompact/icons/crazy.gif
Larry
/ Learning how - WELDING #31
When you guys decide to buy a welder, hunt around and find a scrap metal yard and pick up a bunch of small pieces. At a yard, you can usally buy scrap for 10 or 15 cents a pound. (The dealer is making a killing at that price, but you can fill a good sized box for a few bucks). You'll want lots of small pieces to play (excuse me, practice) with. When I first got my welder, I went through several spools just sticking stuff together. For no other reason that the fun of it. (Told the wife I was trying to make LAWN ART /w3tcompact/icons/laugh.gif). It's nice to be able to stick 2 pieces of steel together and wack em with a hammer.
Also, watch yard and estate sales and find an old skill saw with a metal body. You want that all metal case. An abrasive, steel cutting blade at Walmart will set you back a couple of bucks, but that old skill saw will cut steel just like a piece of oak board. Then, shop around for an angle (side) grinder. With those two tools and your welder, you can handle most of what comes up.
SHF
/ Learning how - WELDING #32
Havent been to this forum for a while, but just wanted to chime in on the TIG issue.
First off, a TIG machine can also be used for stick welding, most of them even come standard with the rod holder. The first time I tried TIG, I did it with no problem at all. It was smooth, quiet and clean. TIG is the slowest of the process, but produces a weld that requires less cleanup, is prettier, and, more importantly, is stronger because it penetrates more deeply.
TIF machines create a VERY intense, small heat-effected area. That means you can sometimes "weld" things together with no filler rod at all. Rods can also be used with a number of different strengths. If you are planning to grind a weld smooth, just choose a "soft" filler metal and quickly grind away the excess :) TIG can also weld dis-similar metals where most other processes cannot.
Since the heat is so intense, our instructor said to always get a model with a liquid cooled torch. You should also be aware that you need a darker lens in the helmet as the TIG arc is quite a bit brighter than other processes.
The drawbacks are the cost of the equipment (about 3-4 times more expensive) and the fact that it isnt very portable.
With all that said...TIG might be overkill for general work around a home/farm. I would like to stress the importance of the classes once again...the difference between a good weld and a bad one are not easily seen on the surface (in any of the processes). Learning the hand position/motion for creating a good weld is much easier when you have someone who know what its supposed to sound/look/work like to help you.
Please take into account as well, that I am far from an expert on these matters, so you might want to check some of the professional welding sites. Nothing against anyone here, but if you want to find out about horses you dont ask a barber. (Hope I didnt offend any professional welders here :))
Interested in something else?
The ultimate in go anywhere welding portability?
100% duty cycle, DC current, and power to weld any thickness of metal? (equivalent in work performance to a Miller Ranger 8 or a Lincoln BobCat -- for only 1/5 the cost)
Three Year Warranty -- and, if you don't like it for any reason, or if it's not everything that they say it is, they provide a 60 day satisfaction guarantee?
How about a welder, made to work in wet dirty conditions, small enough that it can be attached to your tractor, with ALL controls for welding in the handle at your fingertips -- driven by your tractor engine, or a truck's engine, or a hydraulic motor, a PTO drive finish mower, or freestanding diesel or gas engines?
IT EXISTS and it is the best welder for farm use ever! (OR for any sort of out door work) I've got one and it is incredible! ZENA mobile welding system -- CLICK HERE TO go to their web site map -- http:// [url]http://www.zena.net/htdocs/Map.shtml [/url].
This is not a message from a beginner who swallowed a marketing line hook, line, and sinker (yes I love fishing). I'm no novice, I've got 20+ years of professional welding experience -- with ALL types of welders indoors and out. This thing is for real!
(And the people who make it are real nice, and very helpful.)
PS: This is a very easy welder to use -- my wife was laying beutiful beads in just a couple of minutes. She canít do that with any of my other equipment -- including my best shop welder.
PPS: She said to tell you that I donít have stock in their company either -- Iíd like to but they donít sell any.
PPPS: As to training, go for the vocational training school -- teachers usually have real-world experience + theory -- invaluable.
/ Learning how - WELDING #34
I don't know who these Zena people are, but they ought to work on their web site. The only thing that works is their home page. None of the links seem to work (and I tried a bunch of them)...
The GlueGuy
/ Learning how - WELDING #35
You got their home page? That's better than I was able to do.
Bird
/ Learning how - WELDING #36
Try this link .
I had no trouble accessing any of the pages on that site. I'm using Netscape 4.7 on NetBSD 1.4.1/w3tcompact/icons/smile.gif
Matthew
/ Learning how - WELDING #37
Must just be a flakey web server/internet connection or something. Last time I checked I was able to get "some" of the links that I couldn't before. Must come and go. /w3tcompact/icons/crazy.gif
The GlueGuy
/ Learning how - WELDING #38
I checked it out the page worked fine for lil o'l me at 19,200 using my cell phone as soon as I read it and again tonight at work...Nice lil welder but doubt I could talk the boss into that much $ when I can pick Up the o'l plugin type for 1/3 less...try as I might I just don't think she would believe I would us it all that much...Course thats ok I'm a paitient fellow..I'll just wait till she really needs something fixed and bring it up then.../w3tcompact/icons/laugh.gif...
Lil' Paul
Proud owner of TC21D
Laziness is the Father of invention.../w3tcompact/icons/laugh.gif
/ Learning how - WELDING #39
I know what we need...WE have a book on Compact Tractors/w3tcompact/icons/cool.gif...How bout a "HOW TO" cd/DVD for welding with video and for those of us that tire out our eyes reading here...Could have close ups (filtered so we can see clearly) of how to get a good bead is it? With the the various types of welding and what each type is best for....How bout it? What do ya'll think?I'm in the boat with LHSmith I have no experience in this area...Would love to learn...But working nights would make it difficult to take a class...I'd hate to fall a sleep in that class...Could end up with a hot foot fast....
Lil' Paul
/ Learning how - WELDING #40
I think Lincoln has a video and a book already. Saw a bunch of stuff from them in the latest Sport Aviation. Seem to be pushing their 175 TIG setup.
The GlueGuy
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2000 Hino (A64194)
2000 Hino (A64194)
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
T/A Drop Deck Equipment Trailer (A64556)
T/A Drop Deck...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
