leaky 318
/ leaky 318 #1
meekss
john deere 318
I have a JD 318 that just started leaking hydro fluid from somewhere in the back axles. It's leaking down the inside of the rear rims. Started slow but getting worst. Does anybody know if this is a easy fix to replace (I would Assume seals) or something else.
Thanks you::confused2:
/ leaky 318 #2
Hello meekss, welcome to TBN! Glad to see you posting. Hope you enjoy being a member of our community. :)
/ leaky 318 #4
Welcome to TBN.
If you are mechanically inclined, give it a shot at the repairs. But If you havent wrenched on anything before, I would advise you take it to a dealer. Maybe if it was a little simpler we couldt talk you through it .
Good luck either way.
/ leaky 318 #5
Look and see if there is some debris that has gotten wound on the axle fouling the seal. May be a simple fix.
larry
/ leaky 318
Thanks for all you replies, I have wrenched things before, I was just wondering If it was real hard. I have heard that if you don't use hydro fluid and use tranny fluid sometimes it's thinner and does'nt work as well. My fluid if red so I figure it's tranny. I might try changing fluid first and see what that does. I'll try anything once, can't hurt!:laughing:
JCB 3TS TELESKID (A65056)
JCB 3TS TELESKID...
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
BRADLEY MACHINE  MINI VAC TRAILER (A67714)
BRADLEY MACHINE...
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
Yamaha EF1000iS Portable Inverter Generator (A66734)
Yamaha EF1000iS...
500 BBL FRAC TANK (A68842)
500 BBL FRAC TANK...
