Leaking water pump
/ Leaking water pump #1
buppy69
Platinum Member
Western NC
Hinomoto E2804, Hinomoto N239,
Can you plug up the weep hole in a water pump and still use it if it is OK otherwise? A local dealer wants $288 for one.
Eugene
/ Leaking water pump #2
No. That is your warning that the pump is going bad. The next warning will be an overheated engine if you're lucky....or a broken shaft and a fan through the radiator if you're not lucky.
/ Leaking water pump #3
Eugene,
Send it to me and I will rebuild it like new for less than half the new pump price.
Thanks,
Bruce
/ Leaking water pump #4
$288 is TOO HIGH. Bruce is right, send it to him. I have never had him do a pump for me but I have sent a pump off for rebuild and it cost me $75. Rebuild is the way to go.
Thanks Fellas.
Eugene
2017 Ford Expedition SUV (A61574)
2017 Ford...
CATERPILLAR DP40 STRAIGHT MAST FORKLIFT (A64279)
CATERPILLAR DP40...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
Adams Weight Hopper (A63688)
Adams Weight...
Forks and Frame Mini Skid Steer Attachment (A61572)
Forks and Frame...
