leaking vlave control ym200bd
/ leaking vlave control ym200bd #1
PrivetFarmer
Has anyone had this problem? It leaks hyd. fluid out of the valve control oil seal. I have replaced the oil seal but I think there is too much pressure behind it. I replaced the o'ring on the spool and that seemed to help for a while. I have not seen any similiar posts on this or any other forum but i can't believe I am the only one who has experienced it.
TIA,
Jim
/ leaking vlave control ym200bd #2
Jim,
When you say valve control...are you talking about a controller on your FEL? Or the valve for implement lock? Not sure which, or what is giving you trouble.
Mark
The valve control assembly which is under the seat and controls the 3 pt. It leaks like a sieve from the oil seal.
Thanks,
Jim
/ leaking vlave control ym200bd #4
I've only had a problem once. I took the valve assembly apart, cleaned with steel wool as it had surface rust from condensation. Reassembled with new O ring and didn't have any other problems.
You might want to check to be sure your vent is clear. Bees have a habit of nesting and closing off that vent.
Mark
/ leaking vlave control ym200bd #5
where is this vent and what does it look like?
Thanks
Jerry
12 Ton Hydraulic Bottle Jack (A64557)
12 Ton Hydraulic...
2018 Ford Escape SUV (A66738)
2018 Ford Escape...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
Future FT-SG45 QA Stump Grinder (A64912)
Future FT-SG45 QA...
