leaking vlave control ym200bd
/ leaking vlave control ym200bd #1
PrivetFarmer
Has anyone had this problem? It leaks hyd. fluid out of the valve control oil seal. I have replaced the oil seal but I think there is too much pressure behind it. I replaced the o'ring on the spool and that seemed to help for a while. I have not seen any similiar posts on this or any other forum but i can't believe I am the only one who has experienced it.
TIA,
Jim
/ leaking vlave control ym200bd #2
Jim,
When you say valve control...are you talking about a controller on your FEL? Or the valve for implement lock? Not sure which, or what is giving you trouble.
Mark
The valve control assembly which is under the seat and controls the 3 pt. It leaks like a sieve from the oil seal.
Thanks,
Jim
/ leaking vlave control ym200bd #4
I've only had a problem once. I took the valve assembly apart, cleaned with steel wool as it had surface rust from condensation. Reassembled with new O ring and didn't have any other problems.
You might want to check to be sure your vent is clear. Bees have a habit of nesting and closing off that vent.
Mark
/ leaking vlave control ym200bd #5
where is this vent and what does it look like?
Thanks
Jerry
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
2021 CATERPILLAR 279D3 SKID STEER (A65053)
2021 CATERPILLAR...
2011 Ford F250 Lariat Super Duty (A66408)
2011 Ford F250...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
Skid steer Fork Bracket  (A62679)
Skid steer Fork...
