Leaking steering box, John Deere 2030
   / Leaking steering box, John Deere 2030 #1
Nedferd
John Deere 401B, 2030, 2950, 1010
My hydraulic steering unit leaks past the base gasket. Return oil from steering is supposed to go back to the transmission pump. Have I missed a return port?
   / Leaking steering box, John Deere 2030 #2
Are you talking about the valve in the console, or the "motor"? The steering valve ports, IIRC are o-ring boss. You need to use hydraulic o-rings that have a higher durometer rating than the cheap nitrile o-rings that cant handle the pressure. If your base gasket is leaking, either your return is plugged somewhere causing an over pressure situation in your valve, or you have a blown gasket. If its in the steering "motor", again, wrong o-rings, bad gasket, or plugged on the return side.
   / Leaking steering box, John Deere 2030 #4
Welcome to this forum
Return oil from power steering control valve on JD utility tractors of that era travels through hole in the mounting gasket back through a galley in clutch housing to trans reservoir.
2348 (A60432)
2348 (A60432)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
7041CFL (A59228)
7041CFL (A59228)
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
