Leaking front tire
/ Leaking front tire #1
kenacp
New Orleans and Liberty Miss
John Dere 770
My front tire (3yrs old) on my 770 is leaking in one small spot on the bead(rim). What is the best method to deal with this? Some sort of leak stop or just put a tube in it and be done with it?
Thanks
/ Leaking front tire #2
I'd deflate it, look at the area & see if you have something lodged in it first. It's not hard to pick up something if you've been doing some clearing or just something being in the wrong place at the right time.
Ronnie
/ Leaking front tire #3
On my 4410 I don't even bother to try to go without tubes anymore. New tires get new tubes. I just have a lot less trouble with flat tires and slow leaks.
/ Leaking front tire #4
I put tubes in the fronts on my JD 4010 at about that point (3 yrs). Tried using that stop leak stuff (Slime?). Worked for a short while.
Ralph
/ Leaking front tire #5
I had very good luck with Slime in my little B2150's front tires a few years ago to plug multiple thorn punctures. But I don't think it would be very effective for a bead leak, where flexing of the rubber against the metal rim will be constant. Just my guess, tho. I'd deflate, check for a foreign object. If the rim surface is rusted or otherwise damaged, I'd just go with a tube, as was suggested.
/ Leaking front tire #6
I've had good luck with slime in my fronts... never bought the stuff until I read about it here.
The rears I had foamed filled... so no chance of a flat!
/ Leaking front tire #7
Years ago the dealership I worked at had this stuff. It even worked on old rusty rims that look like they would never seal. VERY sticky stuff, try not to get it on your hands or anything besides the bead. You break the bead and spray it on the bead then re-inflate the tire.
Just recently I tried finding the HUG stuff locally and struck out...settled for the NAPA branded stuff that brushes on. So far I'm 0-1 using it on car rims so I'm planning to buy some HUG from my old boss next time I visit my folks.
/ Leaking front tire #8
Bite the bullet tube both front tires one less headache down the road.
/ Leaking front tire #9
Tube for sure is one good solution.
What often can happen is a bit of water get in there, some rust starts and air leaks out of the rusty (porous) area.
Pulling the tire and wire brushing the rim will cure that type of problem but it will just come back as bare metal will rust.
1990 FORD LT9000 HOT OIL TANK TRUCK (A67714)
1990 FORD LT9000...
2013 CHEVROLET CAPRICE CAR (A66091)
2013 CHEVROLET...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
2022 CHEVROLET GM515 SIVERADO 4X2 S/A FLATBED TRUCK (A67737)
2022 CHEVROLET...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
