lawnmowerforum problems?
/ lawnmowerforum problems? #1
tom3
Southern, Ohio
JD l130 Sears GT5000
Is the lawnmowerforum a sister to this site? Can no longer log in to the site, get a pretty scary message from all browsers. Any help? This is a copy/paste of the message I'm getting:
Did Not Connect: Potential Security Issue
Firefox detected an issue and did not continue to www.lawnmowerforum.com. The website is either misconfigured or your computer clock is set to the wrong time.
It痴 likely the website痴 certificate is expired, which prevents Firefox from connecting securely.
What can you do about it?
www.lawnmowerforum.com has a security policy called HTTP Strict Transport Security (HSTS), which means that Firefox can only connect to it securely. You can稚 add an exception to visit this site.
Your computer clock is set to 6/15/2019. Make sure your computer is set to the correct date, time, and time zone in your system settings, and then refresh www.lawnmowerforum.com.
If your clock is already set to the right time, the website is likely misconfigured, and there is nothing you can do to resolve the issue. You can notify the website痴 administrator about the problem.
/ lawnmowerforum problems? #2
It seems to be a common issue on the lawnmowerforum website. Happens about every couple months. Something about the security certificate gets messed up. It will get fixed sometime and we will be back to normal until it happens again. ILengine
/ lawnmowerforum problems? #3
Been having the same problem..!
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
Bush Hog 3Pt Post Hole Digger (A66408)
Bush Hog 3Pt Post...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
Pipe Rack 5'9"Wx16'Lx6'6"H (A62679)
Pipe Rack...
