Larger HST tractors?
/ Larger HST tractors? #21
I just spent a few hours in the field (golf course) with the JD4720
and one of the 2.4 liter Grand L40s. We wanted the 5740, but got
the 4740, which has the non-turbo engine and a few hundred #s
less weight. I gotta say that the HST-plus is the most impressive
HST I have yet tried. Esp like the Auto Throttle.
I have a question on Kubota's "Response Control", which I think works
the same as JD's "Load Match". I suspect these two systems use a
solenoid control to vary the position of the HST hydraulic motor's
swash plate and there are 2 fixed positions. Does anyone have good
info on how they work? NH has a system like that, but I do not know
what it is called.
/ Larger HST tractors? #22
dbk123 said:
Sure. Feel free to send me a note if you have any specific questions.
Did you get to compare the cruise controls on each tractor?
/ Larger HST tractors? #23
Lots of them still in service as loader tractors.
D7E said:
I'm not sure of the age but i remember late 70's/early 80's the "IH HYDRO 84" they were a flop but a few were around i never used one but i presume it was a IH844 with a hydro...?
They were worth nothing quite new...?
/ Larger HST tractors? #24
Closer to 15 gpm if they have an updated pump. 12 was the majic number I believe on the factory pump.
Sometimes when looking at hydraulics I find that a smaller pump might do more then larger just do to the valves and other parasitic losses on the design.
New/Unused Grapple for CFG Mini Excavator (A61166)
New/Unused Grapple...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
KUBOTA BX23SLB-R-1 TRACTOR (A62130)
KUBOTA BX23SLB-R-1...
Cummins 6-Cylinder Diesel Engine with Transmission (A61568)
Cummins 6-Cylinder...
iDrive TDS-2010H...
LAND PRIDE CAT. 1 QUICK HITCH (A62130)
LAND PRIDE CAT. 1...
