Oil & Fuel Large diesel engine
/ Large diesel engine #22
Can you just imagine also how many gallons of diesel it need on board of the ship? Just imagine the weight of all this and it still float....
Diesel is lighter than water. A large vessel like this has such a volume to surface area ratio that filled with diesel it would still float.
Note; The weight of a large ship tends to follow the surface area (square of the size) while the cargo carrying space goes with the cube of the size. Therefore the larger the ship the greater load it can float percentage wise compared to its unladen weight. A large ship made of steel could be entirely filled with diesel and still float very well indeed.
If enough of these monsters are put to sea with heavy loads, each displacing its own weight in water (see also, Archimedes) it will raise the level of the Earth's oceans and contribute to an even earlier and more severe ecological disaster than Global warming alone.
...BUT it won't take off no matter what sort of conveyor belt is employed!
Pat
/ Large diesel engine #26
johnk said:
What the heck does the starter look like?? It must be as big as a house. What kind of power plant energizes the starter? Must have high tension towers on the docks.
Hi,
Slow speed marine diesel engines are usually started with compressed air, through specially timed air start valves (air admitted after TDC, to push the pistons down to start rotation.). Obviously these engines would require large quantities of air and they have specially designated "start air compressors" for this purpose (high pressure, high volume). The air compressors usually electrically driven and suitably sized - probably three in number.
These large engines can run with one or two cylinders not firing - lift the fuel pump to prevent fuel going to the injectors. Newer engines use pneumatic controls (air cylinder) to lift the cam follower off the camshaft and hold it there. No repairs can be done with the engine running as there are no disconnects to the pistons. connecting rods etc. And yes, just the piston, piston rod, crosshead and connecting rod constitute several tons in weight - possibly as high as 15 or 20 tons for the ship mentioned - and that is per cylinder unit.
jim
/ Large diesel engine #27
It would be good for gangsters to get rid of bodies, they could just throw 'em in the air intake. :cool:
John
John
Yes!, but only after dousing the body with 2 or 3 different diesel fuel additives.
Pat
/ Large diesel engine #29
Yeh, we're, uh, addin' fuel stabilizer. Yeah, dat's it. You gotta prob'm widdat?
/ Large diesel engine #30
If the gangsters wanted to make a body disapear, they feed them to pigs. Pigs can eat and dissolve everything including teeth.No DNA. If you don't believe me ask the detectives looking for my X-wife!!
/ Large diesel engine #31
A member on DHS Diecast posts quite often about the world's largest equipment. His name is Tim Twichell, and he used to host Mega Machines, or one of those programs several years ago. He had a post about the engine. From what I remember, the crankshaft weighs 300 tons alone.
One of his more current postings is about the Thialf, which is the world's largest heavy lift, floating crane. It consists of a self-propelled platform with two large cranes on one end, each lifting 7,300 metric tons, 14,600 metric tons total. In our units of measurement, that being the short ton, it lifts 15,200 tons. It is used mostly to set the superstructure on top of leg assemblies of off-shore oil platforms.
If anyone is curious, type in Thialf in the search bar, and check out the sites.
I always look forward to his posts on DHS Diecast, because I know I will not be disappointed.
Regards, Colin
/ Large diesel engine #32
I still like bacon!:)
John
/ Large diesel engine #33
AWESOME!!!!!!!!!!!!!!!!!!!!!!!
Once that thing is built, I'm guessing that it would have to be disassembled to install it in a ship.
Wish I could have caught that show featuring it.
/ Large diesel engine #34
I watched a show about this and what struck me was, Diesel himself designed this engine way back when.
/ Large diesel engine #35
4 days to carry that ship from Asia to us, then another 10 in Port to refuel!;)
/ Large diesel engine #36
You have to wonder if it would be more cost effective for them to power those ships with nukes?
/ Large diesel engine #37
Dr Diesel also built the first diesel engine & proved it worked. Trouble was, the engine blew up the first time he fired it & almost killed himself.
Now, without using a web search, can anyone tell me what fuel Dr Diesel used in his first engine? :D
Attached is a pic of an exhaust valve from one of the main engines I was responsible for while in the Coast Guard. It wasn't a very big engine, in the grand scheme of things. 10.5" piston with a 12" stroke, in-line 8-cyl 4-cycle, it idled at around 210 RPM & a centrifugal plunger in the flywheel shut the fuel system down at just over 700 RPM. It was only rated at 700HP, but I'll guess it made well over than 2000 ft/lbs of torque. "Winging" the throttle (by pushing on the output lever of the governor) at idle would rock the 180' long ship 3-4 degrees.
/ Large diesel engine #38
dbdartman said:
...just over 700 RPM. It was only rated at 700HP, but I'll guess it made well over than 2000 ft/lbs of torque. ...
:eek: 700HP @ 700 rpm is over 5000 ft/lbs of toque:eek:
Must have had a lot of entertainment value.
/ Large diesel engine #39
LOL! I guess that is "well over 2000 ft/lbs!" All I know is those things (we had two on the ship, each turned a 700KW generator that powered a single 600HP DC motor spinning the screw) were LOUD! Even louder when one tossed the top of a piston, at 2AM! :eek:
/ Large diesel engine #40
Here is why you won't see any more US non-Military Nuclear Ships anytime soon...Remember the owner of the ship is the owner of the waste...:rolleyes:
This is what the shutdown of the N.S. Savannah has gone thru thus far...
To close a nuclear power plant permanently, federal law requires that the facility must be "decommissioned." This is accomplished by safely removing it from service and reducing residual radioactivity to a level that permits release of the property and termination of the operating license.
The Nuclear Regulatory Commission has strict rules governing nuclear power plant decommissioning and these rules involve the cleanup of radioactively contaminated plant systems and structures, and the removal of the radioactive fuel. The NRC's rules and requirements protect workers and the public during the entire decommissioning process and continue to protect the public after the license is terminated.
The U.S. Maritime Administration, which manages the NS Savannah for the federal government, has been complying with all the NRC rules and is utilizing those rules to guide this decommissioning project.
The requirements for decommissioning a nuclear power plant are set out in NRC regulations (Title 10 of the Code of Federal Regulations, part 20 subpart E, and parts 50.75, 50.82, 51.53, and 51.95).
The Nuclear Regulatory Commission has published a detailed Fact Sheet on decommissioning. To view the NRC's Fact Sheet, click here to download the PDF file (You must have Acrobat Reader installed to view this document.)
Decommissioning the NS Savannah.
Although the NS Savannah has been defueled for many years and is considered radiologically stable, there is much decommissioning work left to be done.
The Partial decommissioning work accomplished in the mid-1970s was principally designed to render the reactor permanently inoperable, and actually left much of the nuclear plant intact. The major components that were removed at the time included the primary system coolant pumps and the primary demineralizer tanks. The rest of the plant components, equipment and piping systems remained intact and in place. Electrical components were tagged out to prevent their operation, and the control rod drive system was completely disabled (mechanically, hydraulically and electrically), and disconnected from the control rods themselves. And of course, all the fuel was removed, along with nearly all of the primary system water, and the highly radioactive demineralizer resins, which were part of the primary water purification system.
Natural decay over the past 30-35 years has reduced the inventory (quantity) of residual radioactive material to a small fraction of the original. What is left is radiologically stable, which means that the inventory will not substantially reduce over the next 50 years because most of the short-lived radioisotopes have already decayed.
In the NS Savannah's reactor decommissioning process, all the remaining equipment on board, and the components and piping associated with the nuclear power plant will be removed and disposed of in Nuclear Regulatory Commission-licensed facilities.
In its simplest sense, decommissioning of the NS Savannah's nuclear plant will be much like constructing the plant, only in reverse. During Construction, precision and attention to detail was required to ensure the nuclear plant was constructed to the exacting tolerances necessary to ensure safe operation. During decommissioning, a similar high standard will ensure public health and safety is maintained as irradiated and/or contaminated components are removed and contaminated surfaces cleaned to NRC decommissioning standards. Worker safety will be ensured by training, planning, scheduling, mock-up rehearsals and coordinating all work activities.
Oversight of the decommissioning project will be performed by both MARAD and the NRC. Final surveys will be performed by MARAD and verified by NRC prior to terminating the nuclear license and completing the decommissioning process.
Public involvement is encouraged throughout the process via a variety of methods, including a planned Citizen Advisory Board. Public meetings will be held throughout the process....(Gee do you think any of these meeting caused more work???....:rolleyes: )
NS SAVANNAH Reactor Decommissioning Project
New 50Pc Equipment Key Set (A65579)
New 50Pc Equipment...
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
Outback Guidance System (A65640)
Outback Guidance...
John Deere 620 Quick Attach Loader with Bucket (A65640)
John Deere 620...
4x6 Utility Trailer (A62679)
4x6 Utility...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
