landscape rake
/ landscape rake #1
ozzy2
1025R john deere
I have a 24 hp tractor what size of landscape rake can i pull
/ landscape rake
I was looking at an 8'
/ landscape rake #5
I had a 60" rake on a 16 horsepower 4WD tractor with ag tires, and it seemed to pull it pretty well. When I would pull gravel up a steep hill, if it got pretty loaded, I'd start to lose traction. I think, worst case, going too wide will lower the speed you can work at, unless it's a traction problem. And you're lowering the speed but taking fewer passes, so at worst the effects will cancel out.
/ landscape rake #6
If you want it for your 1025 an 8 foot rake might be a bit optimistic, if you plan to use it to it's full capacity. I'm not sure if it would work anyways without modifications as the tractor is rated as "Limited Cat 1." According to the Frontier Implements website Frontier™ Landscape Equipment | John Deere US a 5 foot rake is the biggest recommended for that tractor.
/ landscape rake #7
seems to me 8' is too much for your size tractor. you might consider loading your rear tires, then a 5' should be ok, anything bigger may be iffy under a full load
/ landscape rake #8
Enough width to cover rear tire tracks set at 45 degree angle.
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2006 Ford F-250...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
