landscape rake
/ landscape rake #1
ozzy2
1025R john deere
I have a 24 hp tractor what size of landscape rake can i pull
/ landscape rake
I was looking at an 8'
/ landscape rake #5
I had a 60" rake on a 16 horsepower 4WD tractor with ag tires, and it seemed to pull it pretty well. When I would pull gravel up a steep hill, if it got pretty loaded, I'd start to lose traction. I think, worst case, going too wide will lower the speed you can work at, unless it's a traction problem. And you're lowering the speed but taking fewer passes, so at worst the effects will cancel out.
/ landscape rake #6
If you want it for your 1025 an 8 foot rake might be a bit optimistic, if you plan to use it to it's full capacity. I'm not sure if it would work anyways without modifications as the tractor is rated as "Limited Cat 1." According to the Frontier Implements website Frontier™ Landscape Equipment | John Deere US a 5 foot rake is the biggest recommended for that tractor.
/ landscape rake #7
seems to me 8' is too much for your size tractor. you might consider loading your rear tires, then a 5' should be ok, anything bigger may be iffy under a full load
/ landscape rake #8
Enough width to cover rear tire tracks set at 45 degree angle.
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A67148)
2013 CORPUS 40FT...
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
2013 FREIGHTLINER CASCADIA T/A 6X4 DAY CAB TRUCK (A67147)
2013 FREIGHTLINER...
2025 TP25 25in Hydraulic Post Puller Skid Steer Attachment (A64553)
2025 TP25 25in...
