Landscape Rake to get gravel back onto road?
   / Landscape Rake to get gravel back onto road? #21
I have a broom (with a couple of wheels to support the weight)for my combi that I run over the grass on the edge of the driveway after the winter snow leaves. Works great to get the gravel back onto the driveway. I do about 700 yards in a couple of hours.
Same here. I go just slow enough ground travel and engine/broom speed appropriate for the gravel amount.
   / Landscape Rake to get gravel back onto road? #22
Try a gas powered leaf blower with a high MPH rating. I have smaller gravel in lawn on the sides and get almost all of it.
   / Landscape Rake to get gravel back onto road? #23
Would a Landscape Rake be the best to move gravel back onto the road? My gravel always ends up on the road edges.
Works for me and saves on not having to purchase additional gravel.
Angle 45 degrees and throw gravel back to center. Then straight (no angle) and two swipes down center of gravel driveway. Repeat when necessary.
   / Landscape Rake to get gravel back onto road? #24
I used my landscape rake for that for a while. But then I got this heavy duty dethatcher from Good Works Tractors. It works much better and is also better at maintaining my gravel driveway and cleaning out the goat pen.
   / Landscape Rake to get gravel back onto road? #25
Another possibility would be this: Driveway Scraper - Driveway Scraper
It pulls the dirt/gravel from the edges towards the center. It works well to level everything out since the landscape rake creates windrows in the gravel.
I still use the angled landscape rake on my driveway also, though, usually first, then switch to the driveway scraper.
Chris
   / Landscape Rake to get gravel back onto road? #26
I have a 1 mile gravel driveway. I also have hydraulic top and tilt.
I use an angled landscape rake to bring gravel back onto the road. I adjust it so that it is slightly above the crown and then float one side. That makes it follow the crown while bringing the gravel back up.
It does an OK job. Usually takes 2-4 passes each way to get most of the gravel back in the road.
I then switch to a Land Plane Grading Scraper. I run it with one side in float so that it also follows the crown.
That system works well for me and I've not needed gravel in about 5 years...but I do now. I figure I'll need 4 loads every 5 years?
I have a scrape blade but it drags too much dirt with the gravel. Landscape rake is not ideal but it is the best I've found.
   / Landscape Rake to get gravel back onto road? #27
I also have a quarter mile gravel roadway to maintain. I started out with a York rake to maintain it and when I upgraded tractors, I bought a used land plane from the dealer. This animal is the one! Even for someone like me!! I adjust the left/right cant with the lift arms on the 3point to match the crown I want and drive down one side of the road and back on the other. Even the best of potholes and occasional washboarding have no defense against this device. Just make sure you grade down through the bottom of any pothole otherwise you are just filling a hole with gravel ( and will soon have it empty again).
   / Landscape Rake to get gravel back onto road? #28
Landscape rake with gauge wheels is very good for getting in gravel from the sides of the road. Set rake tilt to match crown and angle rake from outside in to center to help move gravel in. Important to fill wheel ruts in. As another has commented, you have to cut down far enough to loosen material in potholes not just push material into them. Any pothole which catches water will drill itself deeper and deeper into road as cars drive through it. If you see potholes, best to do a quick rake whenever potholes start to develop. Don't let them get big. Hydraulic angle and tilt for rake is a real timesaver.
Problem is that any leaves and trash which have settled on the outer foot or so of the road are balled up and brought in, too. You have to stop and fork them out, so organic material is not mixed into the road, making it soft.
10 years ago I bought a very powerful 13 HP Billy Goat blower. Now, in the fall I make a pass up and down the road after most leaves fall but before they get so much rain they are waterlogged. I leave the ditches completely clean. Much better for winter storm drainage, and prevents washouts when plugged ditches force water back onto road surface.
When I rake, I get more clean gravel and road material back and I don't get as much leaves and trash in what I bring back. If I am raking at other times of the year, I usual spend an hour blowing the road sides clean before starting if they aren't completely clear. I haven't had to buy as much additional road material since I started blowing off trash.
When raking, it sames me time if I don't pick a day when road is completely dry and hard. You don't want a wet, soft surface, but a couple of days after a rain when the surface is still not fully set up will save time and rake passes. Gauge wheels on the rake prevent surface washboards caused by tractor nodding over bumps.
   / Landscape Rake to get gravel back onto road? #29
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2010 HEIL TOKEN TRAILER (A53843)
2010 HEIL TOKEN...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
Towable Light and tower (A55851)
Towable Light and...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
