Rake Landscape Rake maintenance
/ Landscape Rake maintenance #1
Mavrik02
Westmoreland Co., SW PA
CK30HST
Ok...I've admit that I've used and abused my lanscape rake. I've used it to rake out the dirt to plant my new yard, freshen up my gravel driveway, cut down small mounds of top soil, and clear underbrush from about 5 acres of woods (the last two were the roughest on the rake). I have snagged it on more trees than I can count and have backed the tines into even more trees than that.
Now the tines are all bent at different angles. They don't sit flat so it is hard to do finishing work with it (however it still works perfectly for most jobs). Is there any way to bend/even out the tines again so they are all the same? Can you purchase a replacement set?
Any wisdom would be appreciated.
P.S. A picture is attached but it is very hard to see from it what I am talking about.
/ Landscape Rake maintenance #2
Heat em up with a torch and straighten with channel locks.
Or buy new tines.
/ Landscape Rake maintenance #3
If you heat the tines to straighten them, you will take the temper out of the steel. Tines are made of spring steel and it doesn't take well to heat. I suggest that you either learn to live with it, or to order new tines from the manufacturer. It is a tool, and with use, it will get some damage. Think of the cost of a few new tines as normal maintenance. If you remove them, you might be able to twist them around with a pipe wrench holding the tine in the vise. Just be careful that it doesnt break and you wind up falling on your arse.
/ Landscape Rake maintenance #4
If your tines are the bolt on type (1 or 2 holes) then you can get new ones fairly inexpensively from Agri-Supply. Here is the catalog page.
Agri-Supply catalog
/ Landscape Rake maintenance #5
I get a pipe wrench and bend mine "cold" to get back in line. I suppose that after numerous bending the tines would weaken but I haven't had to do it too often so the rake should out last me since I get "bent out of shape" once in a while also. /forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif
/ Landscape Rake maintenance #6
Never heat the tines,they not you,will lose there temper. I raise the rake up 2- 2 1/2' then slip a piece of pipe over the tine and get-err-done. If tine tines are easily removable,remove clamp in vise,and still use the pipe deal. I've bent and straightened the tines this way many times. Good luck!
/ Landscape Rake maintenance #7
I have a Woods landscape rake. Do you suppose those Agri Supply tines would work in it? I get Woods parts from my dealer, but they are $9.00 a tine. I had a bunch break the other day when I put the rake down and started moving backwards.
/ Landscape Rake maintenance #8
If I am not mistaken, the Woods tines are either 1 or 2 bolt tines. If so, then the Agri-Supply tines will work. They are made in Italy which is where most, if not all, of the tines used by the various manufacturers come from.
/ Landscape Rake maintenance #9
I thought the rakes were designed to be used backwards. At least under limited load for something like smoothing soil over grass seed.
/ Landscape Rake maintenance #10
excuse me fellas, but are you guys serious? If they are so damaged that they require replacement, then there's your answer. But each tine has it's own pent up stresses, pressures, and it is a fiction of marketing that they are strait when they are new. When you expose them to the stresses of work as the tool that they are, they react in different ways.
If bent tines on your landscape rake upsets your sense of the universe this much, I'll trade lives with you!
/ Landscape Rake maintenance #11
Why don't you call Gary at Midwest and ask him about replacement tines? I'm sure he'd be more than willing to sell you tines and ship them to you. I bought my rake and rear blade directly from him and had them shipped to me, for a better price than any competitor's products from my local dealers. Here's a link to the Midwest website: Midwest Manufacturing
/ Landscape Rake maintenance #12
Mavrik, I think you've got the same rake as I do (LR20-72) and I suppose I've abused mine somewhat too. Is the top channel on yours twisted? Mine is. I caught some of the tines on one end on a small stump that I didn't see until it was too late, hung it up and twisted the top channel. /forums/images/graemlins/frown.gif After doing that I noticed that the tines seemed to be loose, but after I tightened up on the bottom clamping rails they seemed to be okay. However I can see the twist, especially at the center in the support gussets. I was planning on taking a 4 x 4 and clamping it perpendicular to on end of the channel and giving it a heave to see if I could straighten it somewhat. I'm a little disappointed that it seemed to twist so easily. I didn't think I was being that aggressive. I guess I'll have to see how easily it is to straighten it. I doubt that this is covered under warranty. I may end up adding some larger gussets to make it a little more rigid.
/ Landscape Rake maintenance #13
When something like that bends I first wonder if it is the intentional weak link. Like that channel is the shear pin that protects something more expensive.
/ Landscape Rake maintenance #14
You would think the tines were the weak link in the chain. I wish they were. They're a lot cheaper and easier to replace.
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
2016 Ford Explorer AWD SUV (A64557)
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
Sunflower Yard Art (A64557)
Sunflower Yard Art...
2002 JOHN DEERE 330C LC EXCAVATOR (A65053)
2002 JOHN DEERE...
