Land Prep/House Build
/ Land Prep/House Build #21
Good luck with the build. It's a lot of fun to watch your house come together. I built mine about 5 years ago, about 10 months start to finish and I did almost everything myself will working 45 hrs a week at my regular job. It was crazy hours but worth it.
I built a 2150 s.f. 1 1/2 story on 17 ac, it was a lot cheaper per s.f. then a ranch would have been. You would be amazed at how much your design affects your s.f. cost.
Just a suggestion, but look at all the little options, you wont regret it. Some of the little thing are so nice to have and may not cost you much more, like heated tile floors, ceiling fan/lights switched separately, dimmer switches, higher R insulation, ect.......and if your going all electric at least entertain geothermal heating. IMO the extra $4k was absolutly worth it.
Thanks for all the kind words everyone. We chose a two story mainly because my wife liked the floor plan. We live in a ranch style house now and like it but a little change never hurts.
I would have like to do a lot of the building myself but with the amount of time i travel it is just not an option (have already put in over 400 hrs of overtime this year).
We have been looking at things for about a year now such as exactly where we want outlets, how many light switches, extra flood lights outside, and on and on. Everytime i sit down and go over the plans i come up with more stuff to add.
One of the things we did do since we are on top of a hill with lots of wind was go with 2x6 walls and R-19 insulation. I figure between the brick, 2x6, and R-19 the house should be sturdy and well insulated.
I'm just starting out with the electic/heat pump for heat because i can't decide which direction i want to go for final heat source, and this way once i do decide i will have the electric as a back up for the future.
Pictures are uploading now, will post them soon.
The masons yesterday laid the first 7 courses of block, only 6 more to go.
This picture is taken from a spot where I will be taking pictures throughout the process so at the end i can do a time elapse slideshow watching the house go up.
My driveway held up fine throughout tri-axels of stone, the tractor trailer that deliverd the excavator to dig the foundation, and cement trucks for the footers. However when the truck came to deliver the concrete block the driveway was messed up big time. It had rained everyday for at least the previous 5 days and his truck sunk in a lot. Here are a couple pics of the semi repaired drive but now i need to figure out what to do next.
/ Land Prep/House Build #25
Lookin good. Geotextile mesh will do wonders to tighten up any loose spots in your drive. Just scrape a couple inches down, lay the mesh, and replace the stone. Or dig down and add some more 1's & 2's (or whatever they call them in PA, 1 1/2"-3" dia stone)
Electric heat pumps have come a long way in the past few year, they can be quite effecient. Not a bad choice to start out with. I do still recommend looking into geothermal though with a ground loop. With 2x6's and brick you should have a nice tight house thats easy to heat/cool.
Your options are pretty much endless as for what you can do. It's great that your thinking about all of that stuff now instead of making changes after stuff is already in, that will kill your budget in a hurry.....
Actually there is fabric then about 4" of shale (now realize that was a mistake), then a layer of 4" stone, and topped with 2A modified (fines up to 1 1/2"). The drive was very tight and solid till the truck with the cement block showed up, but i think the issue is all the rain we've had lately and the fact that the drive hasn't really seen much traffic yet. Hoping with maybe another load of 2A modified it will tighten back up.
/ Land Prep/House Build #27
Warning: Unsolicited advice coming! :)
Before you pour that basement slab, put radiant tubing down. It will cost a couple hundred extra bucks, but it is one of those things you just CAN'T do later on, and will regret if you don't. Even if you never hook it up, it hasn't cost you much, but I bet you will hook it up at some point, and you won't believe how you got by without it.
/ Land Prep/House Build #28
Geo grid is different then fabric. We have had great luck tightening up soft spots with grid. What you plan to do should work, but if it doesn't you may want ot look into the grid.
FWIW, I wouldn't worry about radon unless you are going to have bedrooms in your basement. Your inner footer tile will do a great deal already to eliminate that problem.
Good luck
Do you have a link to information about the geo grid? No plans for a bedroom in the basement, just a mud room, man cave, bathroom, furnace/utility room.
As long as the rain holds off they will finish the block today, Monday waterproof, and start framing middle of next week.
/ Land Prep/House Build #30
I have not used this exact product, but here is a link to the type of product I am refering to - BaseGrid Geogrids for Base Stabilization - US Fabrics
If you find that you do need some your best bet may be to call some local site contractors and see if anyone has a small piece laying around. Suprisingly it works wonders.
Sorry for such a long delay in updating, between travelling for work and moving out of our house it has been very busy.
On to the pictures,
Here is some of the stone delivered and the basement mostly braced, almost ready to start backfill.
Here are the piles of stone to backfill the garage. I was worried if they used the shale that came out that even with compacting it that it would still settle too much and i would have cracks in the garage floor.
As you can see that was basically no topsoil here on top of the hill.
Now we can move on to framing, these guys were amazing. It was a mostly Amish crew that came out of Ohio and were staying local so they worked long days, 6am - 930pm. They did a great job, i am very happy with their work.
Some pictures of the framing.
End of day 1.
Basement
First floor
2nd Floor foyer
2nd Floor
/ Land Prep/House Build #32
Nice looking house in an AMAZING setting. I bet the views will be amazing when you are living in there!!!!!
Eddie
All prepped and ready for concrete.
Starting on the brick
Eddie
Thanks, the views are amazing and make it all worth it.
/ Land Prep/House Build #35
I like that you have a side-load garage like we have. It's nice to see house instead of two or more garage doors on the front elevation.
/ Land Prep/House Build #36
That house is looking great. Very similar to what we have been looking at building. I agree the view you will have will be amazing and also like the side entry garage.
/ Land Prep/House Build #37
looking great! And you're making some seriously fast progress......
Time for another update.
Brick and siding was finished by 6-29
I am very happy with how the brick turned out and am glad we decided to brick the whole house.
Here are a couple pictures of the kitchen before and after the cabinets. I need to get more pictures of the inside as painting and flooring is done and i'm now installing trim.
This is the load of red oak trim right after i picked it up.
This shot is from a neighbors back yard.
CAT 320EL Hydraulic Thumb (A68134)
CAT 320EL...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2016 CHEVROLET IMPALA LIMITED CAR (A66091)
2016 CHEVROLET...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2000 NEW HOLLAND 5554 BACK HOE (A66091)
2000 NEW HOLLAND...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
