Land Plane diving in and overloading
/ Land Plane diving in and overloading #21
I have heavy duty rear blade and LPGS. Hydraulic top link is the only way to go. Unless you get your jollies - up and out of the seat making unending adjustments. Makes attachment of all my implements go easier also.
Even if you are okay with a manual crank top link you won't do the job as well as a hydraulic link. I maintain 1 mile of improved dirt road. I find constant small top link adjustments allow me to cut and fill as needed while moving. This is the key to getting good long term results.
/ Land Plane diving in and overloading #22
I made the one I have from a box blade and welded the blade mounts to sheets of steel that line up with punched slots in the side. This allows you to lift the blades completely above the surface you are dragging over, only allowing a "cut" on high spots.
That 2" ball on the back is so I can drag this 3000 lb roller behind it for compaction.
Cutting up the box blade for the plane also gave me a box I could use to drag over lose material to level with.
I do have a hydraulic top link but I don't use it with either of those.
/ Land Plane diving in and overloading #23
You are so right, scooter. And you make - and see any adjustments - "on the go". You don't have to accept - well, that's good enough. You "tune" the attachment until it's doing "exactly" what you want.
/ Land Plane diving in and overloading #24
Speaking of tuning attachments. I put a cylinder on my rake so I could change the angle on the fly. I added a water barrel on the LP so I could cut the hard packed washboard on the road. A water barrel allows infinite weight adjustment depending up the volume of water up to nearly 500 pounds.
/ Land Plane diving in and overloading #25
I've only used homebrew landplanes (two) and both had chains for toplinks. The dig and drop were regulated via raising and lowering the 3PH arms. We thought of the mount to be more like a bush hog and didn't want the rigid toplink that could interfere with the landplane following the contours.
/ Land Plane diving in and overloading #26
That's a very nice setup Scootr!
/ Land Plane diving in and overloading #27
That was my thought too, seems like you'd want it to float like a bush hog.
/ Land Plane diving in and overloading #28
View attachment 5051355View attachment 5051354
Do you find that the ripper teeth are needed alot with this land plane setup?
/ Land Plane diving in and overloading #29
If I am maintaining roads, they are up. More often than not the rippers are up with blades cutting 1/2" below skids.
I have used them on ground where I would have otherwise needed to go get something else to tear up the ground first.
Quicker to raise/lower them than swap implements and they already existed.
I have also never needed to add any additional weight to it.
/ Land Plane diving in and overloading #30
I use the rippers on my land plane under two conditions. Making a new path/trail out thru the unbroken ground ( pucker brush ). And on the driveway in the late summer - when the driveway is hard as 30 year old concrete. I've never had to add my home made weight - 30"x30"x14". Around 150 pounds of concrete.
I used the home made weight years ago. Smaller tractor - lighter back blade.
/ Land Plane diving in and overloading #31
I think you left out a "0" ... Closer to 1050 Lbs ...
Cured concrete weighs roughly 145 - 150 Lbs per square foot ...
30x30x14= 12,600 cubic inches
A cubic foot - 12x12x12 = 1,728 cubic inches ...
12,600 cubic inches divided by 1,728 cubic inches (1 cubic foot) = 7.29 cubic feet ...
7.29 cubic feet x 145 Lbs = 1057 Lbs.
/ Land Plane diving in and overloading #32
Oops!! Correct Shawn. Right at 1050 pounds. One of the reasons I never used it. Way too much weight.
/ Land Plane diving in and overloading #33
Its pretty much done. Drove on it back and forth a lot with my Dodge Cummins. I'll wait a few weeks to let it pack even more before a final scraping.
That's a pretty nice spread. If you're able to form a crown - even better.
/ Land Plane diving in and overloading #34
I spread a loader bucket of gravel going forward. Back drag it with the bucket to rough smooth it. This is with the B26TLB backhoe. Then I switch to the BX2230 with the landplane. I drop the landplane down, take the control out of float and back over the new spread gravel. Kind of like back blading, but the runners try to prevent digging in. My landplane is a LandPride GS0560. Small, light weight for the BX2230. Non adjustable blade setting. Blades set low the runners, but runners don't seem long enough to support the landplane from digging in. Jon
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
2006 John Deere 6420 (A64126)
2006 John Deere...
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
