Labour content over-charge
/ Labour content over-charge
Sounds like the latch needs to "stick out" more so that it can fully latch...
Aaron Z
Have had a play around with the 'stop' moving it in different positions but still doesn't close shut. I think there may be a problem with the latch. Problem is there are two part numbers for the latch and I'm not 100% sure which would fit.
AR91893 now RE50874 use with lh door no rh door. My cab doesn't have a full opening right hand door but it has a lower quarter opening work door/hatch on the right, so not sure if JD would count that as a door or not. Can upload a photo if it helps.
AR92006 now RE62482 when fitted with rh opening door.
What the value difference between the $ and money in N Z? Hy-gard oil is plenty high in N Z @ $55 per gallon. The muffler was about twice as high also. AL35753 MUFFLER ASSY ADD 221.45 USD vs $450.87 N Z. 80 hrs labor is a lot but they did a lot of repairs.
Hy-gard was charged at $55 per LITRE ( I think 1 gallon = about 3.5 Litres? )
Sorry more questions...... Would like to know whether there is a screen filter that needs to be cleaned in the hyd pump? The pump I'm referring to is in front of the diesel tank.
When the PTO is running, where is yellow lever on the dash supposed to be? I assume it should be at the top when the PTO is running but it seems to stay in the middle when the PTO is running.
Hopefully I have explained that properly, there is a photo of the cab on the first page that shows the lever to the left of the steering.
Also what is the correct procedure to engage and disengage, foot on clutch when engaging?
TBH I'm an amateur when it comes to these sort of things :eek:
/ Labour content over-charge #23
Whats your tractors SN or post photo of opening. Does your tractor have a SG2 cab??? JD Hy-Gard is $78 per 5 gallon can here in Texas which equates to $15.60 per gallon.
Code: 214BU
Serial: 555321L
Yes tractor has a SG2 cab.
See photos below of the opening on the right hand side, sorry for the poor quality photos.
3pt Heavy Duty Carry-All, 3'x6' Platform (A62679)
3pt Heavy Duty...
2001 Volvo Sleeper (A62613)
2001 Volvo Sleeper...
1994 Freightliner Day Cab (A62613)
1994 Freightliner...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
1999 MACK MIXER (A65643)
1999 MACK MIXER...
Steel Blasting Shed (A62679)
Steel Blasting...
