LA463 QA
/ LA463 QA #1
billblough
Sarasota, Fl.
Kubota L3400HST
Just wondering? Does the LA463 QA backplate match up with other brand attacthments or do I have to buy a special backplate for each attachment?
I don't know if I am making sense with my question.
/ LA463 QA #2
I just installed the QA adapter on my LA463 loader arms. It is a standard skid steer type adapter, and will work with standard skid steer plates on the various implements. I haven't seen an LA463 with QA from the factory, but I assume they use the same adapter that I bought from Kubota to retrofit my LA463.
/ LA463 QA #3
I'd say it's probably the skid steer QA that you got.
/ LA463 QA #4
/ LA463 QA #5
bigballer said:
Guys - I am thinking about converting my LA463 to QA and am curious how much to budget for this.. How much did you pay for the LA463 QA adapter? How much do the receiver plates cost that are welded to the bucket? I assume these are kubota specific parts?
For aftermarket, I found this link but am not sure if anyone had done this with their LA463??
Kubota Tractor Skidsteer Q/A Adapters, Skidsteer Attachments,Hayforks,Palletforks and Tractor Canopies
Read this one. http://www.tractorbynet.com/forums/...115587-another-qa-conversion.html#post1330593
/ LA463 QA #6
The old LA463 lacks some stops that are needed to keep the coupler from hitting the loader. The LA463-1 has those added. Its an easy fix, but its somhing your dealer should do.
/ LA463 QA #7
Neil: Thanks for the post. This is the first I've heard about a 463-1. Any way for me to tell which one it is?
What is the part that needs to be added to make it compatible with the QA?
I don't think that I will be able to do a QA conversion until some time in the future but I have no relationship left with my dealer so I will probably get a local welding shop to help me out with converting the bucket (or convince my wife that I need to get a welder and learn some welding skills!).
/ LA463 QA #8
bigballer - I found this one to be interesting. Probably the only aftermarket one I have seen that is not as heavily built as others like Horst. Those come in at 140 lb or so and given the loader's capacity, might as well not put any more steel into the adapter than necessary. The OEM one looks nicely built also - but expensive here in Canada unless I pick it up on the fall during a road trip to the USA.
/ LA463 QA #9
/ LA463 QA #10
This is interesting. I was fairly thorough in a side by side comparision of an LA463 to an LA463-1 and every thing seemed to match, aside from the QA. My dealer did a quick cross reference of the loaders and QA part #'s, including the L2230A and felt they matched up but we both wondered why Kubota would not endorse a retrofit for my LA463.
Messicks, any more info. about the stops? A photo?
Anyway, I did the retro fit with the L2230A and every thing seems to have worked out perfect. Bigballer, I picked up mine for $380 even and it was well worth it.
/ LA463 QA #11
There is a stop missing from the old loader. I forget exactly what the conflict is but its possible to damage the old older unless you weld a stop on. As I recall, I think it is the one that was in the picture. Lots and lots of tractors go out of here that I never see. This was one of them, I just remeber the other sales guys talking about it. I think we just welded up a stop ourselves.
/ LA463 QA #12
My dealer quoted $545 for the Kubota QA Adapter and $530 for a new bucket (66"). I can have them convert my existing bucket for $125 + ~3 hours of shop labor at $85/hr. It's close to a wash on the price of new bucket vs converting old bucket. I am still considering a pin-on grapple as well since it would save me a bunch of money and I am not sure I would want to add any other loader attachments, maybe pallet forks but I don't really see a need for that at this point. I could also get one of the $299 QA adapters and save some $$ there, I suppose.
decisions, decisions....
/ LA463 QA #13
You can save alot of money if your able to do it yourself.
/ LA463 QA #14
If I was going to get a skid steer QA, I think I might be best off putting the money towards getting a welder and some cutting tools and learning how to weld.
I'd probably need someone with some experience in welding to do it with me but money better spent then paying for the labour.
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
Bucket (A64194)
Bucket (A64194)
New Quick Attach Power Spreader (A65579)
New Quick Attach...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
3ft Metal Ford Tailgate (A65583)
3ft Metal Ford...
2007 Chevrolet Silverado 1500 Pickup Truck (A64194)
2007 Chevrolet...
