LA302 Quick Hitch forks
/ LA302 Quick Hitch forks #21
That does help! Looks like you have had a few heavy loads on them! :laughing: Looks like the top link pin is bent down and the left pin is bent up! I will have to do some checking to see if I can make them universal front and rear mount. Thanks.
The flat-bar metal welded to the guard was already bent that way!... I had a pile of scrap metal and that's the best I could find!:D
Now the left lower pin is bent up, Because that's the way it turned out when I welded it!:laughing:... It was hard to back up to the forks and measure to figure out where I needed the pins.... I also had to adjust my 3PT Hitch so it would be level.
I made the lower pins... I used a piece of 3/4" round-bar, bored out a hole through the 1/2" flat-bar, and welded the round-bar on the backside... Then I slid a piece of pipe ''over'' the round-bar, and filled the end up with weld!... They fit better in the HF Quick Hitch with the pipe.
I didn't have a sharp 3/4" drill bit at the time, So I had to cut out the hole with Oxy'/Acet', and the holes was a little large!... Try holding the round-bar in a loose hole so it can be welded!!!:D:laughing:
Oh, And yes I have had some heavy loads on the Forks!!:)
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED SDLANCH...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
Adams Tilt Trailer (A63688)
Adams Tilt Trailer...
Utility Cart (A59231)
2015 TIGERCAT 234 LOG LOADER (A64276)
2015 TIGERCAT 234...
2012 Ford Expedition SUV (A61574)
2012 Ford...
