LA302 BUCKET LEVEL INDICATOR
/ LA302 BUCKET LEVEL INDICATOR #11
Hey Kubota, whats with the crappy level indicators on your smaller FEL's?
Week 3 of projects for me....since there is no snow to ride the sled on, I decided to get another project done.
Do you have the crappy level indicator that Kubota puts on the smaller loaders? I laughed when I saw it and asked the dealer if there was an option for the rod type indicator, Nope was the answer so I have been looking at different types and Used a modified version I saw on a Mahrinda.
I started by making new pins for the curl cylinder to make them 1" longer then drilled the center and tapped it with 5/16x24x 5/8 deep. Made an "L" bracket out of .090 material at work with a 5/16 hole on one side and 3/4 hole on the other side. Then made a rod 7/16 dia. 28 1/2" long and welded a small lug on the end with a 5/16" hole and bolted it to the lower curl pin. Then I bolted the "L" bracket to the upper curl pin. Next I cut a piece of 1/2" i.d. tube 22" long slid the tube over the rod and into the "L" bracket, with the bucket level I matched the end of the tube to the end of the rod and welded it there. DONE! About 3 hrs. and I now have a level indicator that is usable!! Simple as that Kubota!!! Total cost is about $5.00!
When the rod is flush with the end of the tube the bucket is level!
I will get some paint on it as soon as it warms up enough.
Nice job, now is there a way to kick out the return automaticly when level? I know I'm asking a bunch, and your's is top of the line for people like me, but continue working on it for the return auto level and kick out with the return lever. Has to be simple without any hyd. changes. Cat used one years ago that pushed a simple pump (manual) that would push the lever into the neutral position when then bucket was level or you could overide with more pressure on the lever.
1988 FRUEHAUF TRAILER OPERATION FUEL TRAILER (A60736)
1988 FRUEHAUF...
(INOP) 2004 INTERNATIONAL 4300 SBA TRUCK (A59823)
(INOP) 2004...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
2001 John Deere 6210 (A60462)
2001 John Deere...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
