L5740
/ L5740 #1
dieselbill
2011 kubota L5740 grand cab with loader
Looking at getting a 5740 cab does that fit in an 8 foot overhead door
with R4 tires on it the book says 94.7 with the ag and i hope it is alittle
smaller with r4s i have about 94.25 to the rubber seal any help would be great
thanks
/ L5740 #2
thanks
I don't have a cab but you should be ok with R 1's as they are a little smaller and you can run them soft which will give you at least another inch.:D
/ L5740 #3
My 4240 with R1s just barely clears the opening of the smaller of my garage doors. It's exactly 8' with a 1/2" weatherstripping. If I drive through the opening the rubber flap on the weatherstripping gets folded over. I would say it's got to clear by 1/4" so 95 1/4". Kubota's site says the height is 94.4 so I think it's going to be real close.
/ L5740 #4
Mine fits in a 8 ft door - I wanna think the actual height was about 92 " ? Have to check it again - But I think I still had about 4-5 " left?
/ L5740
thanks for info do u like 5740 how is that snowblower work for deep snow and drifts
/ L5740 #6
IMO Nothing compares to it for drifting snow. I can get drifts around 5 - 6 ft from a inch of snow fall when the wind kicks up. My driveway is cut in a hill which makes it a pain to deal with at times. I will try and get the exact tractor height measurements tonight and get back to you.
/ L5740 #7
IMO Nothing compares to it for drifting snow. I can get drifts around 4 - 6 ft from a inch of snow fall when the wind kicks up. My driveway is cut in a hill which makes it a pain to deal with at times. I will try and get the exact tractor height measurements tonight and get back to you.
/ L5740 #8
Sorry it took so long, I measured it and the height was between 91 & 92 inches. I could not get an exact because I did not have a second set of hands. I fell that is pretty close though.
That's with R-4's also, Hope it helps-
/ L5740
Thanks alot it is nice to know that it will fit my garage all the dealers by me have them still on the crate so i couldn't find one to measure thanks again
Bandit 200XP Chipper (A63689)
Bandit 200XP...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
Kobelco SK135SRLC-1E, Cab, Heat/Air, Manual Thumb8 (A62679)
Kobelco...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
PRIEFERT PORTABLE CATTLE SQUEEZE CHUTE (A64277)
PRIEFERT PORTABLE...
