Snow L5030 in snow
/ L5030 in snow #1
mnkub
Kubote L5030
Pic from this past weekend...
/ L5030 in snow #4
I have tractor envy! /forums/images/graemlins/laugh.gif :
/ L5030 in snow #5
I have a 3830 with a front mount 62" blower, haven't had to use it this year so far, I got the blade on right now. How wide is the one on the 5030? However I did build a cab on mine and it remove easily in the spring.
/ L5030 in snow #7
Very nice picture, not to mention beautiful woods. /forums/images/graemlins/grin.gif
What brand of snow blower are you using?...............J
/ L5030 in snow
The blower is a Kubota. I forget the model # but it is right around 62" wide. I was astounded at the ability to throw snow at such a distance. This was an 8" storm but I would venture that the 5030 could handle at least twice that before it would have to slow down. Probable capable of clearing snow at the depth of the intake at a reasonable speed.
/ L5030 in snow
One more...
/ L5030 in snow #11
VERY NICE! appears to be a light granular snow, and if you get any wind in the wrong direction you are going to be very wet and cold /forums/images/graemlins/grin.gif check into a cab for that sweetheart
/ L5030 in snow #12
Awesome picture. I couldn't tell if you had Ag tires or not. How well does the l5030 handle snow and ice compared to a 4wd truck with new snow tires? (Never been on snow or ice with the tractor ... yet). We usually get a foot or two (stop laughing) in NW Ark.
/ L5030 in snow
I've got R4s / Industrial tires. Funny you should ask about the traction. Before I realized there was a detent in the forward position of the FEL control which allows the blower to float I definitely had a problem. Either the blower was so low that it was lifting the front wheels practially off the ground and I had no traction whatsoever for steering, or the blower was too high and I was leaving a lot of snow on the ground that I was just passing over. Embarrasing, but once I found the float position I had no problems whatsoever with steering or traction. My feeling is that the L in 4WD has better traction than does my Suburban in 4WD. I drove up a pretty steep hill while blowing and never spun the tires once.
Re the cab - definite must to build or purchase something for next season...
/ L5030 in snow #14
Got any idea what ground speed (mph) you were making while blowing?
Bob
/ L5030 in snow #15
That's certainly is a nice setup you have there. I have the B2660 attached to a B2400.
What sort of chute do you have on that blower? I have the 60 inch model blower but the chute is much shorter and doesn't have the two piece deflector that yours has. I get a lot of snow blown at me because it's so short. Also, I'd like to get my chute to be a little higher so I can pass the snow over the mail boxes when I'm right next to them. I can load them real fast if I'm not careful. It'll knock over a full trash can too. I'd hate to get hit by that stream of snow!
It looks like the very top of your chute is almost as high as your chin while sitting in the seat. I'll bet the chute's sideways reach is significant as well.
Would it be too much trouble to ask you to measure the height of your chute and post a couple of close ups of it?
/ L5030 in snow
No problem. I'll take some shots of it tomorrow and post. A quick measurement shows the top of the chute to be 39 1/2" above the blower. The blower is also Kubota brand.
/ L5030 in snow #17
I agree, I gives a new meaning to the Polaris phrase, "The Way Out!" or "in" whichever. /forums/images/graemlins/wink.gif
/ L5030 in snow #19
mnkub,
That is one nice tractor and snowblower setup you have! I agree that is Postcard material! With as much snow in the picture I can't imagine ANYONE up North NOT having a tracor and snowblower of some type.
I do have a question for you as we DO NOT have that much snow here in East Tennessee. When running the snowblower, "How Fast" are you moving. I have it envisioned that you are moving like baleing hay, but never seen anyone in real life doing it! Sorry if that seems like a dumb question, but with 2-3 inches at a time and melts away, I have never known or seen anyone snowblowing. I tried downloading a .wav file in another post, but I am on Dial-up and times out before it will load.
Thanks for the reply! /forums/images/graemlins/smile.gif
/ L5030 in snow
I never looked at the mph but I did spend most of my time in mid range (HST). I probably was at the slower end of this range mostly because I was watching the side of the driveway. Machine was capable of working at a brisk walk / slow jog.
Case IH 4200 Combo Mulch-Soil Finisher (A66285)
Case IH 4200 Combo...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
Titan 20.5-25 Tires (A65640)
Titan 20.5-25...
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2012 TROXELL...
Kubota L175 Tractor (A62613)
Kubota L175...
Cattle Feeder (A65640)
