Jun 23, 2010 / L4400 compare to JD4005 #1 C coach S New member Joined Jun 23, 2010 Messages 6 I am in the process of buying a new tractor and I like both the Kubota L4400 and John Deere 4005. Anyone familiar with any of the two or both? Also what tires would you recommend, the Ag or the industrial? Thanks.
Jun 23, 2010 / L4400 compare to JD4005 #2 D Deerlope Veteran Member Joined Jun 28, 2003 Messages 1,653 Location Northern, New York Tractor Kubota L3830 03: RTV 900 As for tires it depends on what you will be doing with it. As for JD or K it depends on how much aluminum you want in your tractor.
Jun 23, 2010 / L4400 compare to JD4005 #3 TripleR Super Star Member Joined Mar 5, 2009 Messages 18,538 Location Missouri Tractor Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford I don't know anything about the tractors, but tire choice is pretty much going to be dictated by your planned uses.
Jun 26, 2010 / L4400 compare to JD4005 #4 _RaT_ Super Member Joined Apr 19, 2000 Messages 5,855 Location Peoples Republic of Northern CA. Tractor Kioti 3510-SE HST Deerlope said: As for tires it depends on what you will be doing with it. As for JD or K it depends on how much aluminum you want in your tractor. Click to expand... I take it your saying JD is still using cast aluminum on the rear axle?
