L4150 starting problems
   / L4150 starting problems #1
Cdnhogman
New Brunswick, Canada
Kubota L4150, MasseyGC2300
I have a L4150 that has a problem starting. When you turn the key most times notking happens or tou just get a click sound. Sometimes after repeated turning the starter will turn over an the tractor starts. Most times it needs a boost and starts as soon as the cables are hooked up. What is the problem?
   / L4150 starting problems #2
Sounds like your battery is on the way out.
   / L4150 starting problems #3
Battery Terminals clean?
Ground at frame clean?
Poz.Cable at Starter Terminal clean?
Whenever I have starting 'Issues' with Machines around here, 9 times out of 10 It's a corroded Connection...
   / L4150 starting problems #4
L4150's are notorious for building resistance in the wiring, connectors, and glow plug circuit reducing voltage to the soleniod. The fix for this, is to install a starter relay circuit so the solenoid will get full battery voltage. Of course you still have to make sure that the battery is good, the grounds and terminals are clean, etc. There is still the chance that the contacts inside the solenoid are burnt too.
Brian
   / L4150 starting problems #5
Advice:
Start with the easy stuff first.
Remove the battery cables, clean the posts and clamps and try again. It is unlikely the battery is bad as it would likely not start after repeated attempts. Normally, a bad battery just gets less and less oomph with each successive attempt.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
1261 (A50490)
1261 (A50490)
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
1998 Ford F800 Water truck (A49461)
1998 Ford F800...
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
