L4150 input needed
/ L4150 input needed #1
NJDonzi
Farmingdale, NJ
Kubota L345DT
I'm picking up a 1986 L4150 4x4 with a BF 900 loader on Monday that I put a deposit on yesterday. I purchased the machine from the original owner with only 1246 hours on machine. Everything works on this machine 100% and it looks to have been extreamly well maintained. All the sheet metal is perfect with original paint...some surface rust here and there but nothing that bad. Tires are 75% or better. It also has a york rake attached. The owner has all the service books and manuals too.
All fluids are very clean. Only real issue I see and owner pointed out is a small leak where 6 X 6 block with four bolts is attached under the machine where it looks like a shaft runs front to back. (Not sure what you would call it) He said he had someone fix it awhile back but it wasnt done right and still leaks some. Looks like its an easy fix and maybe just a gasket.
Also the battery light is lit on the dash. But machine started right up with no issues. Maybe needs an alt. ? Bad wire?
Other than those 2 issues everything else is dry and super clean. Everything I have read on this machine has been very positive and It looks like this is one of the better models that Kabota built.
Now...for the good part. I paid $8,000 for this machine.
Thoughts???
Thanks
Scott
/ L4150 input needed #2
The original Kubota battery had a cell with a water level indicator switch in it. Most owners don't buy another Kubota battery so the wire just dangles and the light stays on unless you disable it.
The 4-bolt 6x6 block is the drive to the front axle. It has a gasket but all the transmission oil has to be drained to work on it. The best temporary fix is some leak stopper putty like Devcon Steel Epoxy from the local hardware store. Someday when you're changing the fluid anyway you could do a better job under there. I'm wondering why it's leaking. Clean it off well with carb cleaner spray and see where the oil is actually coming out. Good luck.
Thanks for the information. I will look into getting the leak fixed when I get it home. Sounds like a pretty simple fix.
Great info on the battery light also!
Scott
/ L4150 input needed #4
That was a great buy imo for $8K.
2014 Impala Limited Sedan (A66738)
2014 Impala...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
Menzi Muck M520 Walking Excavator Mobile Excavator (A66734)
Menzi Muck M520...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
PORTA POTTY (A68842)
NISSAN 35 MAST FORKLIFT (A67714)
NISSAN 35 MAST...
