kubota nut
I have a L39 that just turned over 500 hours. It has a quick attach option for the front bucket and a set of forks. My Problem: When I raise the bucket to the top and rotate the bucket there is s lot of slop. to the point of being a saftey issue. This TLB has been lubed at least every 10 hours. I've pulled the pins in front and there is very little visable wear, however, the brackets that the pins go through seem to be worn. I.m going to take in brackets to a machine shop and see if steel bushings can be inserted . Does
anyone know if this is a reacurring problem or if there is some type of simple fix that I just dont know about. It seems as if the metal on the brackets is awfull soft.
