L3600 GST stuck in 4x4, advice please
   / L3600 GST stuck in 4x4, advice please
I bought it! It has a few small oil leaks and it's not new but it runs great, shifts fine and the tires are in goodshape. The best part? After running it around in the dirt for a few minutes and working the 4x4 lever up and down it started working. I didn't tell them that and I made a big deal about the oil leaks.
$8480 OTD and they're going to deliver it!
   / L3600 GST stuck in 4x4, advice please #23
That's fricking awesome!!!!! You applied what I call the KISS principle. Keep It Simple Stupid. Their ignorance is your bliss!!!!! Good steal!!!!!! Only thing I see it lacking is QA bucket. You can convert that fairly easy. Especially if you buy the FEL QA head. Then build the bracketry on the bucket.
Awesome!!!! Good job!!!! :cool:
   / L3600 GST stuck in 4x4, advice please #24
Wow!!!
Thanks for your help guys. I'll probably be back for more advice in the near future. I'm tickled pink! Oh and the seat is lose, I talked them into fixing that before they deliver it.
   / L3600 GST stuck in 4x4, advice please #26
I figured as much - the 4x4 was likely bound up from tension. I could jump up and down on the 4x4 lever on my L4200 without it popping if its bound up. Rolling on dirt, however, it slides in and out like buttah. Nice rig and nice score, BTW.
   / L3600 GST stuck in 4x4, advice please #27
When you get it home, check all the fluids, test the anti freeze, grease all the fittings (especially on loader), change the hydraulic filter, and check the air pressure in the tires. If you didn't get a manual, get an owners manual and service manual on ebay or elsewhere ($15-$20).
Then just run that Glide Shift through the gears - Smooooooooooth! Print out a hard copy picture of your new baby so you can explain that $h**eatin grin on your face.
PS: I think putting a fire extinguisher on the ROPS is a good investment.
   / L3600 GST stuck in 4x4, advice please #30
Nice work!!! That's a lot of tractor for the money!!
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
HOMEADE 4 BOLSTER LOG TRAILER (A51243)
HOMEADE 4 BOLSTER...
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
Kubota BX2230D (A47384)
Kubota BX2230D...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
