Oil & Fuel L3600 Fuel Tank
   / L3600 Fuel Tank #1
buddym
guntersville, al
kubota l3600
I have a L3600 with a fuel tank that is leaking. It is not a hose but is coming from the bottom of the tank. It looks difficult to pull out the tank but that is what needs to be done. Doe anyone have a shop manual or experience in doing this.
Buddy
   / L3600 Fuel Tank
I did get the tank off, but I had to cut the bracket that surrounds the tank. I will just weld it back but was there an easier way?
   / L3600 Fuel Tank #4
Welding around the fuel tank should be no problem:rolleyes:
   / L3600 Fuel Tank
Found small stress crack in bottom of tank, no rust. Cleaned out remaining fuel and fumes and was able to weld it. Checked for leaks seems to be fine. Will weld up bracket with no fuel in tank.
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
case 370 glass door never installed (A61306)
case 370 glass...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2371 (A60432)
2371 (A60432)
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
