L3540 losing power
   / L3540 losing power #1
ddb123
Platinum Member
Southwest MO
Bad Boy MZ 42"
Was mowing today and noticed that the tractor wouldn't achieve much speed in M low or M high. RPMs would bog way down when peddle was pressed. Giving more throttle didn't help. In fact, tractor seemed slightly starved for fuel. Idle was around 500 RPMs rather than the usual 800 or so. Full throttle was about 2500 vs the usual 3000.
My first thought is the fuel filter, but wanted to check the hivemind and see what others think I should check. Tractor has never given me any problems other than this and only has about 200 hours.
   / L3540 losing power #2
Start by changing the fuel filter and checking the air filter.
   / L3540 losing power #3
Black smoke under load would indicate the air filter is plugging as indicated by the filter minder device turning red.
No black smoke under load would indicate fuel starvation.
Regards, Fred
No black smoke. Checked the air filters and they looked fine. Heading to the Kubota dealer today to pick up the fuel filter. Will update with progress. Thanks!
   / L3540 losing power #5
Definitely a plugged fuel filter or weak transfer fuel pump
Went ahead and changed the fuel filter, although the old one looked brand new. Didn't help.
The problem appears to be worse than I originally thought. On fairly level ground, in M low, with PTO engaged (finish mower), RPMs at 2700, and not moving, pushing my foot slowly forward, tractor barely moves and a white or blue, almost invisible smoke emerges from the front. I believe it comes from the exhaust, which usually means unburnt fuel (I think) but this is much less blue. HST operation seems very jerky, that's how I initially noticed something wasn't right yesterday.
   / L3540 losing power #7
Bad fuel?
How long has the tractor sat before you used last?
Maybe a couple weeks. Full tank, from two different re-fills.
It acts like it's under serious load even when it's just rolling.
Well, there is definitely something wrong with it. I thought maybe it was a transmission problem, so I just now ran it in and out of 4wd, through all the ranges, and at various throttles. The tractor seems to run more or less okay at 2000 RPMs or fewer, but at 2500 sitting still without the PTO, it spits out a lot of that thin, light smoke. Does NOT appear to be coming from the exhaust.
The engine also surges a bit at idle. Not enough to really appear on the tach, but enough to hear, at about one-second intervals. I usually wear earbuds when on the tractor, but the engine doesn't sound right, either.
   / L3540 losing power #10
Still under warranty?
The fuel transfer pump might be on its way out.
Fred
No warranty and not the brake, although I thought it was the brake at first.
   / L3540 losing power #13
Sounds EXACTLY how mine acted when the fuel filter was clogged.
Can you ensure the lines are open and completely unrestricted? When you changed the filter, did the lines seem ok? Not collapsed or pinched anywhere? Maybe take the filter out and see how well fuel drains through the lines.
I agree with the others, maybe the pump. But I tend to lean toward a clog or restriction somewhere, especially with only 200 hours.
In any case, sounds like it's starving for fuel.
Well, the bad news is: I'm an idiot. The good news is: I'm an idiot. I had about 50% gasoline in my fuel tank. One of my dad's buddies came by and checked all the fuel lines and filter. He didn't like the look or smell of the fuel, so we poured some on the ground and threw a match on it. It burned like gas.
I never thought it would be a relief to do something so stupid! Thanks for all the input, everyone. You were right, it was a fuel problem. :eek:
   / L3540 losing power #15
Whew! Glad you found that. Don't beat yourself up -- that's an easy mistake. I had my tractor on the trailer and was stopping at the gas station to fill it up. I was on the phone with my wife, and I had to catch myself to grab the diesel instead of the gas pump. It's an easy mistake to make.
Broom Attachment (A59228)
Broom Attachment...
New Holland 3930 (A60462)
New Holland 3930...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2018 RoGator 1100C (A61307)
2018 RoGator 1100C...
2017 John Deere 6120E (A53317)
2017 John Deere...
2469 (A60432)
2469 (A60432)
