L3400 questions
   / L3400 questions #11
Somebody like Bob Skurka could give you all the details on this... but, in most states you are still liable for tax in your state if you buy out of state. It seems that items that big do get noticed and is easier to be traced if it is financed. Something to check into.
   / L3400 questions
Just took delivery of a new L3130 with the 723 FEL. Nice machine! Now it's time to go out and play and get it a little dirty.:eek:
   / L3400 questions #13
How much did you end up paying for the tractor and loader?
Post some pics of that baby. I'm finding that the more I use my 2800, the more I like it.
   / L3400 questions
The new orange toy is now dirty. Went out back and pushed some manure and moved a large tree that fell several years ago that I never got to. Paid $17.5 K for the tractor and loader.
   / L3400 questions #15
STEVE A: I have been a Kubota owner for 30 years and still have four of them. My most recent purchase was a 04' L2800 gear drive, which is a semi-shuttle shift; i.e., you select fwd./ rev. with the side select lever, and in fwd. mode, either low/high range. You have four fwd in low range, and the same in high range, by selecting the amount of speed or power required with the gear shift handle. In reverse, you have four speeds in low range only. For my work, it's Kubota at it's best again, for getting all the power to the wheels!
This is my opinion only; for your six acres, from your post, I don't think h.p, is an issue? You will run out of traction before you ever run out of power with the L2800, by using the correct gear. However, with the HST, go with the L3400. Unless mowing a lawn is a requirement also, go with the R-1 tires for the added traction, and at least $400 savings in your purchase. I use my L2800 for both and selected R-4's, and spend most of the time in 4wd, mostly for traction on any hills.
In closing, if you take reasonable care of a Kubota, the problems will be few and far between in it's life. I have not had an issue for 30 years! Good luck to you on your purchase.
   / L3400 questions #17
Lets see some pics with some dirt on it........Here's one of mine.
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
208316 (A58375)
208316 (A58375)
