L3400 PTO grind
/ L3400 PTO grind #1
fma1015
Raymond, WA
Kubota L3400
When engaging the PTO on my Kubota L3400, I get a grinding sound. It does not matter if the attachment (mower) is attached or not, it still grinds. Can you help me figure out what to do?
After doing a little research, I did this and:
I adjusted the freeplay of the clutch pedal. I can get the PTO going without grinding if I let off the clutch pedal about 1/2 inch from the floor before moving the PTO lever over. If I get the PTO up to speed and push in the clutch, it grinds when I let it back out. Is there something else I can try, perhaps adjusting another rod down there near the clutch pedal rod that I did before where you loosen the lock nut and tighten it? There are other similar rods down there and one that goes the other way down below the one I adjusted does not move when depressing the clutch pedal.
Tractor has 288 hours on it.
Thank you!
