L3400 3-point hitch adjustment
   / L3400 3-point hitch adjustment #41
...and still deny a problem...
They have too, so they can make money. Every car manufacturer has done the same thing... deny everything. Now if we can find an e-mail correspondence from kubota that acknowledges this "issue"... :cool:
   / L3400 3-point hitch adjustment #42
I could live with it dropping an inch if the dang thing would lift smoothly;)
I got the tractor completely reassembled today with the valve adjusted for a 0.006" gap between the set screw and the poppet valve. If the weather co-operates tomorrow I should be able to hook up a couple of different implements and try lifting and lowering to check smoothness and lift capacity.
I'm looking forward to being able to put the lift arms exactly where I want them during hookup without fiddling up and down a few times.
I was able to anneal the copper washers for the hydraulic piping, so the total job cost was a few liters of UDT to make up what I lost removing the pipe several times, and a bit of sealant for the transmission case cover.
Time spent would be in the area of 10-12 hours actual hands on, about half of that was yesterday's trial and error session with different valve settings.
If this fix works with no drawbacks, it'll turn the L3400 into an ideal tractor for our needs. Before it was like a pretty woman with an ugly ol' wart on the end of her nose ;)
Sean
   / L3400 3-point hitch adjustment #44
Sean
Worse! A gorgeous girl that farts in bed!!!!!
   / L3400 3-point hitch adjustment #45
Mike I'll let you in on a secret they all do. Just some wait till you fall asleep before they do it. :D
Boone
   / L3400 3-point hitch adjustment #46
Boone
Ha ha! I know that bull! Im talkin big loud belly warmers, then she laughs at you!!!!!
   / L3400 3-point hitch adjustment #47
Well I don't know about the gals in bed, but as for Sean I think a big round of applause is due from all of us L series owners. Finally after all this time we get definitive answers, and I like that a lot.:cool2: Sean, way to go sir.
James K0UA
   / L3400 3-point hitch adjustment #48
James K0UA
Well said James ! :thumbsup:
Boone
TX.S Sean
   / L3400 3-point hitch adjustment #50
All I have within easy reach in the garage was the logging winch, the rear blade is about 200 feet away. When you're trying to drive standing up with one hand holding the seat switch depressed, 200 feet is like 200 miles.
I have a "before" video with the rear blade already on Youtube, so once I get things reassembled I'll take another "after" video with the blade attached for a better comparison of the difference.
For now...
Kubota L3400 3-point hitch after valve adjustment - YouTube
Sean
I will pay for your flight down and back to Mass if you want to make mine work that well
JCB Loadall 506B Lull (A57453)
JCB Loadall 506B...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2014 MACK CHU  PINNACLE DAY CAB (A55745)
2014 MACK CHU...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2005 John Deere 330CL (A55272)
2005 John Deere...
2013 RAM 3500 FLATBED (A58214)
2013 RAM 3500...
