L3130 Three Point Hitch Issue
   / L3130 Three Point Hitch Issue
Jim,
Planning to call a dealer tomorrow. Have 5 dealers within a 60 mile area. Someone should know. Was thinking, I wonder if there are screens like this in front of each control block. Something for a catastrophic failure and spewing parts downstream?
Thanks,
David
The dealer general response is if the strainer was in from the factory, it should be there. One service manager said it is just added insurance if something goes wrong upstream in the hydraulic system. Not a stock item-special order.
David
   / L3130 Three Point Hitch Issue #43
The dealer general response is if the strainer was in from the factory, it should be there. One service manager said it is just added insurance if something goes wrong upstream in the hydraulic system. Not a stock item-special order. David
Thank you for sharing all the info with us!
   / L3130 Three Point Hitch Issue #44
I guess you just got stuck with an oddball part failure. The question is, did you order the screen? If you decide to leave it out, as Clint Eastwood said, "Do you feel lucky...?"
Not feeling that lucky. Screen on order. Just have to pull rear hydraulic block and trans cover to reinstall. I should have the screen end of next week. They sure don't give them away. Probably .25 of steel screening-dealer price of $24.59.
David
   / L3130 Three Point Hitch Issue #46
I think I would have cleared and reformed the old one.
Thought about that. Didn't want to take a chance on it being brittle and coming apart to drop into the trans sump.
David
   / L3130 Three Point Hitch Issue #48
Just found this thread. Glad you have it figured out and hope the final fix isn't too tough.
Picked up new screen the other day and installed yesterday. Did order new o-rings the same time. Now that I have been in the hydraulic block before, it is no big deal. Had the whole job done in an hour. Big thing is keeping everything clean. That screen is clamped between the trans cover and the rear hydraulic control block with an o-ring-doesn't look too secure, especially when the o-rings harden with age.
David
   / L3130 Three Point Hitch Issue #50
David
Hmm - Sounds like you were just unlucky. Must be that there are other screens waiting to break free and cause trouble.
Nice reporting on this issue David. Thank you.
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
