L3130 Three Point Hitch Issue
   / L3130 Three Point Hitch Issue
Jim,
Planning to call a dealer tomorrow. Have 5 dealers within a 60 mile area. Someone should know. Was thinking, I wonder if there are screens like this in front of each control block. Something for a catastrophic failure and spewing parts downstream?
Thanks,
David
The dealer general response is if the strainer was in from the factory, it should be there. One service manager said it is just added insurance if something goes wrong upstream in the hydraulic system. Not a stock item-special order.
David
   / L3130 Three Point Hitch Issue #43
The dealer general response is if the strainer was in from the factory, it should be there. One service manager said it is just added insurance if something goes wrong upstream in the hydraulic system. Not a stock item-special order. David
Thank you for sharing all the info with us!
   / L3130 Three Point Hitch Issue #44
I guess you just got stuck with an oddball part failure. The question is, did you order the screen? If you decide to leave it out, as Clint Eastwood said, "Do you feel lucky...?"
Not feeling that lucky. Screen on order. Just have to pull rear hydraulic block and trans cover to reinstall. I should have the screen end of next week. They sure don't give them away. Probably .25 of steel screening-dealer price of $24.59.
David
   / L3130 Three Point Hitch Issue #46
I think I would have cleared and reformed the old one.
Thought about that. Didn't want to take a chance on it being brittle and coming apart to drop into the trans sump.
David
   / L3130 Three Point Hitch Issue #48
Just found this thread. Glad you have it figured out and hope the final fix isn't too tough.
Picked up new screen the other day and installed yesterday. Did order new o-rings the same time. Now that I have been in the hydraulic block before, it is no big deal. Had the whole job done in an hour. Big thing is keeping everything clean. That screen is clamped between the trans cover and the rear hydraulic control block with an o-ring-doesn't look too secure, especially when the o-rings harden with age.
David
   / L3130 Three Point Hitch Issue #50
David
Hmm - Sounds like you were just unlucky. Must be that there are other screens waiting to break free and cause trouble.
Nice reporting on this issue David. Thank you.
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A51039)
Ditch Witch 6510A...
2018 Nissan Murano S SUV (A50324)
2018 Nissan Murano...
Unused Delta Crash...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
2008 MAGNUM LIGHT PLANT (A50854)
2008 MAGNUM LIGHT...
