L2800 starting problem
/ L2800 starting problem #1
familyman
Platinum Member
Perkiomenville, Pa
Kubota L3800HST
Hi gang,
A newly developed issue....
My L2800 (260 hours) will no longer simply start and continue running; I have to hold the key in the start position (starter engaged, engine running) for 5-10 seconds before the engine will continue idling on it's own.
Any ideas on where I should "start" looking for the problem?
Thanks, as always.
Charley
/ L2800 starting problem #2
I'd start with a new fuel filter. The only other thing would be the glow plugs aren't preheating.
/ L2800 starting problem #3
New air filter, too...
How is it once it's up and running? So this is just a Starting problem? What is the temperature where the tractor is???
Do you pre-heat? (turn the key to the left for a few seconds)
After some fiddling, I believe it's the key switch. I'll take it apart and see what's up....
/ L2800 starting problem #5
Twice I've had a mouse make a home behind the instrument panel... I flip up the rubber around the steering wheel to look inside for any grass... got them before they chewed on wires!!! Might be worth looking behind there...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
Caterpillar Lift Truck Parts and Service Manuals (A63117)
Caterpillar Lift...
2014 Nissan Quest Van (A61574)
2014 Nissan Quest...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
2010 CHEVROLET PICKUP 3500 HD 4X4 CREW CAB (A59912)
2010 CHEVROLET...
Kuhn FC400RG (A60462)
