L2800 starting problem
/ L2800 starting problem #1
familyman
Platinum Member
Perkiomenville, Pa
Kubota L3800HST
Hi gang,
A newly developed issue....
My L2800 (260 hours) will no longer simply start and continue running; I have to hold the key in the start position (starter engaged, engine running) for 5-10 seconds before the engine will continue idling on it's own.
Any ideas on where I should "start" looking for the problem?
Thanks, as always.
Charley
/ L2800 starting problem #2
I'd start with a new fuel filter. The only other thing would be the glow plugs aren't preheating.
/ L2800 starting problem #3
New air filter, too...
How is it once it's up and running? So this is just a Starting problem? What is the temperature where the tractor is???
Do you pre-heat? (turn the key to the left for a few seconds)
After some fiddling, I believe it's the key switch. I'll take it apart and see what's up....
/ L2800 starting problem #5
Twice I've had a mouse make a home behind the instrument panel... I flip up the rubber around the steering wheel to look inside for any grass... got them before they chewed on wires!!! Might be worth looking behind there...
LANPRIDE FSP700 POLY SPIN SPREADER (A64280)
LANPRIDE FSP700...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Pull-Behind Spreader Tractor Attachment (A61572)
Pull-Behind...
2017 Ford F-250 Reading Service Truck (A61573)
2017 Ford F-250...
