L2800 Random Spring Identification
/ L2800 Random Spring Identification #1
Powereng
West Michigan
Kubota L2800, Z122R
Working in my shop this morning I noticed this random spring laying underneath the rear axel of my L2800. My tractor is a 2008 with only 175 hours and this spring is bare steel with no visible rust. I didn't notice anything missing after crawling underneath the tractor for 15 minutes. I know it's a long shot, but any guesses where it might of come from.
FYI, no one else has access to my shop so I don't think anyone is playing a trick on me.
FY
/ L2800 Random Spring Identification #2
Could it be from the seat suspension? I would start there.
/ L2800 Random Spring Identification #3
Maybe the seat suspension? Look under the seat.
If it is, then time to go on a diet……..(ha ha)
/ L2800 Random Spring Identification #4
If it's not a seat spring, in my experience a spring that robust doesn't tend to drop from where it was installed. Rather they are usually under a certain amount of tension/compression and more resemble a rocket when they fall out of assembly.
I would hazard a guess it's from something/somewhere else and found its way under the tractor, maybe helped along by a cat or something similar...
/ L2800 Random Spring Identification #5
Does this tractor have a backhoe or FEL or both? Maybe look closely around those attachments. The quick attach part of the loader has springs on the vertical locking pins I think. Held in place by split roll pins I think. No real help -- just more places to look.
Seat springs are in place. No backhoe. Going back out to check over the FEL.
/ L2800 Random Spring Identification #7
From the WAG bin: that burly thing looks like some I've seen on attachment slip clutches, where they wrap the bolts and provide tension.
Z.
  • Good Post
Reactions: JWR
/ L2800 Random Spring Identification #8
Z.
That's a darn good guess. It does look like a slip clutch spring. However it is hard to picture a slip clutch coming so totally apart as to lose one of those springs. Maybe a spare someone had ?
John Deere 7230 (A62180)
John Deere 7230...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
8087 (A61165)
8087 (A61165)
2008 Ford F-450 Flatbed Truck, VIN # 1FDXW47R68EA20949 (A61165)
2008 Ford F-450...
