L2800 Random Spring Identification
/ L2800 Random Spring Identification #1
Powereng
Member
West Michigan
Kubota L2800, Z122R
Working in my shop this morning I noticed this random spring laying underneath the rear axel of my L2800. My tractor is a 2008 with only 175 hours and this spring is bare steel with no visible rust. I didn't notice anything missing after crawling underneath the tractor for 15 minutes. I know it's a long shot, but any guesses where it might of come from.
FYI, no one else has access to my shop so I don't think anyone is playing a trick on me.
FY
/ L2800 Random Spring Identification #2
Could it be from the seat suspension? I would start there.
/ L2800 Random Spring Identification #3
Maybe the seat suspension? Look under the seat.
If it is, then time to go on a diet……..(ha ha)
/ L2800 Random Spring Identification #4
If it's not a seat spring, in my experience a spring that robust doesn't tend to drop from where it was installed. Rather they are usually under a certain amount of tension/compression and more resemble a rocket when they fall out of assembly.
I would hazard a guess it's from something/somewhere else and found its way under the tractor, maybe helped along by a cat or something similar...
/ L2800 Random Spring Identification #5
Does this tractor have a backhoe or FEL or both? Maybe look closely around those attachments. The quick attach part of the loader has springs on the vertical locking pins I think. Held in place by split roll pins I think. No real help -- just more places to look.
Seat springs are in place. No backhoe. Going back out to check over the FEL.
/ L2800 Random Spring Identification #7
From the WAG bin: that burly thing looks like some I've seen on attachment slip clutches, where they wrap the bolts and provide tension.
Z.
  • Good Post
Reactions: JWR
/ L2800 Random Spring Identification #8
Z.
That's a darn good guess. It does look like a slip clutch spring. However it is hard to picture a slip clutch coming so totally apart as to lose one of those springs. Maybe a spare someone had ?
skeleton / rock bucket (A56857)
skeleton / rock...
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
Zero Turn Mower (A59231)
Zero Turn Mower...
2013 MACK CHU (PINNACLE) (A60736)
2013 MACK CHU...
2020 Peterbilt 579 (A60462)
2020 Peterbilt 579...
1999 John Deere 7810 (A60462)
1999 John Deere...
