L2800 Fuel Filter Bowl
/ L2800 Fuel Filter Bowl #1
bocash3
Nebo NC
Kubota L-2800 Backhoe
Kubota L2800 with Front End Loader, Backhoe, and 753 hours:
Howdy, just did a 200 hour service myself. Difficult being now partially paralyzed below the belt from spinal cord damage.
With fuel filter bowl cleaned and new filter and large outer O-ring was duly installed, I looked back at the owner's manual.
Manual clearly shows a Smaller O-ring in top-center of filter bowl. Only thing I can figure is that one was lost during
last 200 hour service several years ago.
So - question: This tractor has run without fault, no fuel leaks at bowl, and old filter and bowl caught minor sediment as it should.
So: IS that smaller O-ring in the top-center of bowl necessary?
IF so, I will order one and re-do this job as It's pretty simple.
THANKING all in advance and have a great week!! "Bo" in western NC
/ L2800 Fuel Filter Bowl #2
Well that little o ring is so that all fuel must go through the filter and without it they is a chance that trash or fine particles could get past the cartridge and in the injectors without it.
Thanks so much Triple! Being half mechanically minded, that's sort of what I thought.
Am very careful when fueling to keep things clean. Fortunately, there was very little tiny sediment trapped in fuel bowl bottom. I will order another filter that has both O-rings and fix this immediately.
Again, thanks so much for speedy reply!! Have a good one, "Bo"
/ L2800 Fuel Filter Bowl #5
youtube offers on how to.
/ L2800 Fuel Filter Bowl #6
I replaced my fuel filter (without using the inner "O" ring), It leaked like a mother... I'm guessing that you might have the "o" ring in there... if it's not leaking.
If it's working fine, don't mess with it...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
Crown RM6025-45 Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2018 International WorkStar 7400 Lely 4,500 Gallon T/A Septic Wet Vacuum Truck (A59230)
2018 International...
UNUSED SDLANCH 20'X20' HIGH END CARPORT (A60432)
UNUSED SDLANCH...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
(APPROX 25) 4X4 POST INSERTS (A60432)
(APPROX 25) 4X4...
