L2550 hydraulic problem
/ L2550 hydraulic problem #1
IanM
Kenwood California
Kubota L2550GST
I have a 1993 L2550GST with 800 hours. It is my vineyard tractor and I love it. Great machine. However occasionally now the FEL and the BS will not operate when I start the tractor. Not after idling for awhile or at any rpm. If I shut the engine off and restart then all is fine. Also if I use the FEL as a scrapper in reverse, pulling soil toward me, the hydraulics for the REL and BS soon stops working. Everything else seems normal. I just completed the 800 hour maintence replacing the filters and all but found nothing unusual and it made no difference. Any thoughts? Thanks in advance.
IanM
/ L2550 hydraulic problem #2
A hydraulic schematic would be great huh?? But since we don't have that I'll take a wag at it....it sounds like a pressure relief valve is sticking open and just by-passing pressure.
I would check belt tension on the pump for good measure
Thanks for the reply. I assume that's the belt that runs the generator. The belt is 10 years old and I think I'll just replace it. Seems tight enough though. Would the shop manual have a schematic for the hydraulics? I refused to fork over the 100 bucks but maybe I should reconsider.
/ L2550 hydraulic problem #4
I don't have a shop manual for my tractor( still in warranty) but I would hope that there is a schematic provided in one. I will find out in a few years when I need one.
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
APPROX (50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A65055)
APPROX (50) UNUSED...
1995 PONDEROSA 16' STOCK TRAILER (A64278)
1995 PONDEROSA 16'...
