L2250 remote
/ L2250 remote #2
I have an L2250 and want to add a remote valve to angle the rear blade. Where can I connect the valve?
Do you have a front loader? If so, look for the power beyond port on the loader valve which is probably plumbed to run to the 3-pt hitch. You can put your remote valve into the power beyond loop after the loader and before the 3-pt.
If no front loader, then intercept the power beyond flow where it exits the main hydraulic outlet and goes to the 3-pt hitch. Insert the remote valve before the 3-pt.
/ L2250 remote #3
Your tractor has an option for a remote outlet.
You also have two hyd blocks, one has the relief valve , and the other is for the loader or whatever, but if you do not have a loader, you can use the small hyd block.
There is even one other option and that is to cut the delivery line and use compression fittings and make lines to feed a remote valve with QD outlets.
Go to Messicks Kubota and enter your tractor data, and they will send you a PDF .
EZ Trail 3400 (A63688)
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2022 EZ-GO ELITE...
2012 Audi Q5 3.2 Quattro Triptronic (A62679)
2012 Audi Q5 3.2...
2015 Chevrolet Silverado Pickup Truck, VIN # 1GCNKPEH7FZ334229 (A65563)
2015 Chevrolet...
2013 CORPUS 40FT  T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
