L2250 remote
/ L2250 remote #2
I have an L2250 and want to add a remote valve to angle the rear blade. Where can I connect the valve?
Do you have a front loader? If so, look for the power beyond port on the loader valve which is probably plumbed to run to the 3-pt hitch. You can put your remote valve into the power beyond loop after the loader and before the 3-pt.
If no front loader, then intercept the power beyond flow where it exits the main hydraulic outlet and goes to the 3-pt hitch. Insert the remote valve before the 3-pt.
/ L2250 remote #3
Your tractor has an option for a remote outlet.
You also have two hyd blocks, one has the relief valve , and the other is for the loader or whatever, but if you do not have a loader, you can use the small hyd block.
There is even one other option and that is to cut the delivery line and use compression fittings and make lines to feed a remote valve with QD outlets.
Go to Messicks Kubota and enter your tractor data, and they will send you a PDF .
2022 EZ-GO ELITE...
207923 (A63290)
207923 (A63290)
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2011 Cadillac Escalade AWD Crew Cab Pickup Truck (A61573)
2011 Cadillac...
1995 Landoll Trailer, VIN # 1LH17AUHXS1007250 (A65563)
1995 Landoll...
2015 Chevrolet Silverado 2500HD Service Truck (A61573)
2015 Chevrolet...
