L2250 remote
/ L2250 remote #2
I have an L2250 and want to add a remote valve to angle the rear blade. Where can I connect the valve?
Do you have a front loader? If so, look for the power beyond port on the loader valve which is probably plumbed to run to the 3-pt hitch. You can put your remote valve into the power beyond loop after the loader and before the 3-pt.
If no front loader, then intercept the power beyond flow where it exits the main hydraulic outlet and goes to the 3-pt hitch. Insert the remote valve before the 3-pt.
/ L2250 remote #3
Your tractor has an option for a remote outlet.
You also have two hyd blocks, one has the relief valve , and the other is for the loader or whatever, but if you do not have a loader, you can use the small hyd block.
There is even one other option and that is to cut the delivery line and use compression fittings and make lines to feed a remote valve with QD outlets.
Go to Messicks Kubota and enter your tractor data, and they will send you a PDF .
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Wooden Wagon Wheel Chair (A61574)
Wooden Wagon Wheel...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
