L2250 remote
/ L2250 remote #2
I have an L2250 and want to add a remote valve to angle the rear blade. Where can I connect the valve?
Do you have a front loader? If so, look for the power beyond port on the loader valve which is probably plumbed to run to the 3-pt hitch. You can put your remote valve into the power beyond loop after the loader and before the 3-pt.
If no front loader, then intercept the power beyond flow where it exits the main hydraulic outlet and goes to the 3-pt hitch. Insert the remote valve before the 3-pt.
/ L2250 remote #3
Your tractor has an option for a remote outlet.
You also have two hyd blocks, one has the relief valve , and the other is for the loader or whatever, but if you do not have a loader, you can use the small hyd block.
There is even one other option and that is to cut the delivery line and use compression fittings and make lines to feed a remote valve with QD outlets.
Go to Messicks Kubota and enter your tractor data, and they will send you a PDF .
Bomag Roller (A61307)
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
1667 (A57192)
1667 (A57192)
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2013 Komatsu PC360LC Hydraulic Excavator (A60352)
2013 Komatsu...
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
