L front axle leak
   / L front axle leak #21
I started this thread, seep due to a failed bearing, play noticeable when I raised the front end with the loader and wiggled the wheel in every direction. Cost was $90 for 2 bearings, seal, and large o-ring sealing the case halls. Standard sockets, couple small pry bars to pull the inside bearing off. One of the simplest jobs a person can do. I wouldn't have needed the inner bearing but safety first as it was running misaligned when the outer bearing failed.
I haven't noticed any wheel bearing play yet, my oil looks like it's seeping from top of (bevel gear case) where it connects to the (front gear case)
Your $90.00 Kubota replacement parts price seams on the low side I thought, then you add in the new oil, you must of save yourself $800.00+ dollars by not going to the Kubota dealership, that's awesome possum. How'd you separate the steering (tie rods) from the front end? I tried a gear puller once and they wouldn't budge.
Quick Attach Pallet Forks (A47384)
Quick Attach...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2006 PETERBILT 379 DUMP TRUCK (A51222)
2006 PETERBILT 379...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
