L-2800 Differential Lock question
/ L-2800 Differential Lock question #1
zene55
Dripping Springs, TX
Kubota L2800
I searched and didn't see my exact qeustion so here goes. I am not 100% sure how to engage the differentail lock. It appears to me ( and the manual is no help) that you depress the lever with your heel and hold it down? I thought it should engage and stay engaged until I depress the lever again. But it appears to me that it only works while I hold down the lever. Am I missing something?
Thanks for the info Ken.
Any other sneaky things that you can think of let me know.
/ L-2800 Differential Lock question #4
You got it. Step on it and hold it. You'll sort of feel it slip into place and both rear wheels will be engaged. To release just move your foot and it will pop back up. Note it may interfere with the tractor turning but it's helpful to get unstuck when you lose traction.
/ L-2800 Differential Lock question #5
Don't use it while you are turning... the rear tires have to be free to turn... How long have you had the tractor?
edit: I see it's a 2010... hopefully the suspension seats work better on the new models... and the other "issues" have been taken care of..
/ L-2800 Differential Lock question #6
Sometime differential lock maybe hard to engage..rock tractor or short spin of tires than try to engage.
Watch out for 3pt hitch lever,more so if wearing large jacket.
/ L-2800 Differential Lock question #7
Yes you are right it only engages when you press down the lever with your foot do to the reason that driving with it on isn't the best for the machine.
/ L-2800 Differential Lock question #8
I agree. Especially if you forgot it and drove out on dry pavement and turned.
CASE CX160D EXCAVATOR (A65053)
CASE CX160D...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
1200 GALLON FLAT BOTTOM POLY TANK (A64278)
1200 GALLON FLAT...
JOHN DEERE 1730 - 6R40", 11R20" VACUUM PLANTER (A64278)
JOHN DEERE 1730 -...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
Spirit scooter (A64557)
Spirit scooter...
