Snow Equipment Owning/Operating Kubota
/ Kubota #1
4merfarmer
Kubota B3350SU
I have a Kubota B2650 which struggles in 8 inches of snow. It has an agricultural type tire. Anyone have suggestions for chains vs tire weights? I appreciate any thoughts.
/ Kubota #2
I use ice chains and rear tires are loaded plus rear blade only need 4wd 5 times.
/ Kubota #4
I use chains (2 link ladder type) on my B2620 with R4 tires (not loaded)....using the rear blade and the FEL for removal of snow. That works for me.
Cheers,
Mike
/ Kubota #5
Chains on the rear wheels.
/ Kubota
Thanks to everyone for your replies. There seems to be only about 2-21/2" clearance between the tire and the forward edge of the fender. Is that enough clearance to avoid damaging the tractor? Any point in chains on the front tires where there is more clearance?
/ Kubota #7
Reading on TBN IIRC,,,,,,some do put chains on the front......some put chains only on the front........It must depend on one's exact situation. And...I suppose it depends on the type of chain .. People on hilly terrain....people in snow belts .....the size of the tractor and the size of the job. etc. also make a difference.
Cheers,
Mike
/ Kubota #8
If you can purchase wheel spacers for your mules rear tires/rims you will be able to use rear snow and ice tire chains more effectively. You should seriously invest in some liquid ballast like windshield washer fluid for the rear tires and you will not need front chains.
/ Kubota
Thank you everyone for all of your great ideas. Since we're scheduled for snow 3 days this week, we will put them to good use immediately.
/ Kubota #10
Just to be on the safe side I had wheel spacers put on rear in case I decided to change chain style...also chain tighteners.
/ Kubota #11
They do make low profile chains and chains can be put on tight. Most people put them on the rear tires because they have brakes. You can use your brakes to steer. You also can use the diff lock to get better traction.
/ Kubota #12
I also have a B2650 which I put 21 gallons of plumbing antifreeze in each rear tire. It does help with the traction, but when the driveway thaws and freezes, still need more. I will be grooving my tires, hopefully next summer if I remember and buy a tire groover, or find one to borrow/rent. I do believe you will need a spacer, as mentioned, to get a little more clearance in the rear between your tire and fender.
/ Kubota #13
When I was looking to add a kubota compact tractor to my fleet. All of the models I looked at were B's and pretty much spacers were a requirement on them all to run chains.
I'm playing with my settings so if this is messed up I apologize.
/ Kubota #15
I have turf tires on my B3030HSDC and am very impressed with the snow traction. They are a deep S shape tread and work very well. I also have Rim Guard beet juice in the rear tires and carry a five foot wide box blade to drag snow away from garage doors and scrape concrete driveway.
/ Kubota #16
My dealer said I needed 3" spacers for rear chains on my B-2601. I have run two different types of chains and find them way too rough on my back with the bouncing. So I switched to Kold Kutter screw in studs. Unless I am pushing up hill on a 10% slope, the wet stuff the State plow pushes in, I have no traction issues. Drive is 25' wide by 100 yards. Then a 100' by 50' parking area. Granted it has been a light snow year, only 16', about 11' less than normal. The studs work great.
/ Kubota #17
Hello DaveinValdez,
So you have R4 tires without liquid ballast and no snow blower to clear your snowfalls??
Have you thought about using turf tires instead of R4's? the ride would be much smoother with snow chains on the rears.
/ Kubota #18
Tires are R4's. Because the machine is a tractor/loader and I have no rear attachments, I have a Kubota factory ballast box on the rear with 500# or gravel in it. I have tossed around the idea of a blower but a place, to blow to, is limited and in one area I'd have to blow it twice to get it moved.
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59914)
2006 STERLING...
Quick Attach Backing Plate (A65579)
Quick Attach...
Cattle Feeder (A65640)
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
New/Unused Wolverine 66in Quick Attach Rock Bucket (A65583)
New/Unused...
