kubota vs. Kioti?
/ kubota vs. Kioti? #161
If I went with the Kioti cab it would be and extra $5,000.
/ kubota vs. Kioti? #162
Wow a lot of good reading! I was set to pull the trigger on a Kioti Dk40se HST, loader, loaded r4 tires and two rear remotes, also would come with 50 service or filters and fluids to DIY. Dealer is about 140 miles and price includes shipping. I have four other Kioti dealers within an hour from my house also but only really care for one of them but his prices were a little high. The best price I ended up with was $21,250 out the door plus I could purchase a tooth bar and pallet forks for cost.
I started out wanting a Kubota (b-series) but the 1/4" valve ended that and then one thing lead to another as far as size of the tractor goes and I started looking at other sizes (kioti and Kubota L series) ect. This past Friday I figured I'd give Kubota one last look ONLY because I think a Kioti DK40 will be just a little bit to big physically and the Kioti CK35 being just a little bit to small. Just can't really figure out which one I'd be better off going with. I do take into account that the tractor might get small after a few weeks of use. The Kubota that I saw on Friday was a L3540 HST + (Cab model) with the LA725 loader2 rear remotes and loaded r4 tires delivered to my house (20 mins away) for $30,258 out the door. Really good dealer.
The reason I like the Kubota is it SEEMs like its a little smaller than the dk40 and a little bigger than the ck35 as far as physical size goes. The cab on the Kubota seems smaller than the Kioti which is good for me. I really don't like the size of the Kioti cab and I will end up using the tractor in the woods in the future.
I understand the pros and cons on these tractors but I'm still torn, money isn't not an issue here, I will buy once and cry once. I like the feeling in the Kubota as far as seeing the front end ect, the Kioti dk40 loader arms are kinda in the way ( for me, mabe with time I'd get used to it?). But even this I like the feeling of inside the Kubota I think the Kioti handles a little better and deep down I really like the Kioti. Kioti TO ME felt like it was built a little better.
Good thing is my wife is behind me all the way. She is even encouraging me to buy a cab model if I go with Kioti and also wants me to purchase a BH. I want a BH and have the $$$ but just don't want to spend it on one. BH for Kioti would be $7,500 KB2485 ($8,750 for a Woods BH90x) or $10,000 for Kubota BH92
Still confused as **** as to what to go with. Will be using it to lift logs (average weight about 1000 lbs each) into a stand to cut for firewood, general work around the property and would LIKE to mow if it wasn't to heavy ( that's where the Kubota looks appealing, but Kioti for the logs).
I had a Bobcat Ct235 same as thw CK35. My L4240 turns tighter and is more agile than what the Bobcat was even though it is larger. Did the dealer demonstrate the auto throttle advance and the dual speed hydro and the Kubota? I would go with a cab, you can add a back hoe later but a aftermarket cab is not as nice as a factory cab.
Sent from my GT-P3113 using TractorByNet
/ kubota vs. Kioti? #163
I think you'll be happy with either. I don't know how much you plan to use it or how far into each season. The cab models are a steep jump but worth every penny in my opinion. Playing a real radio and not headphones along with no need for ear protection when running implements, staying cool in the hot summer, staying toasty in the winter, no wind to contend with (tractor wind burn(we've all been there), not getting covered in dust when working the machine, no worry of running over ground hornets and getting stung and most importantly it offers more protection. Although it may be more pricey to fix, if you roll or potentially have something fall down on you, your safer. (Lol, or tree branches smacking you while in the woods).
I love my L3540, it does what I need it to. With that said, good luck and Happy Tractoring!!!!!
/ kubota vs. Kioti? #164
Tough choice no doubt, while I chose a Kubota Grand L and absolutely love the HST+, I think you will be happy either way you go. I didn't fully appreciate the HST+ until I used mine for a few hours and was honestly a bit underwhelmed by my parking lot trial run. The higher cost of the Kubota was worth it to me, but won't be for others.
/ kubota vs. Kioti? #165
What do you plan on doing with it? the FEL on the DK can lift 2700lbs.
/ kubota vs. Kioti? #166
Kioti comes with half the backhoe paid for for the same price. Get the 18" bucket, amazing how much work you can do. Come on... Make your wife happy! :laughing: (give her the bh for xmas) :thumbsup:
/ kubota vs. Kioti? #167
Both good machines. Bit both a bit heavy for real finish mowing.
/ kubota vs. Kioti? #168
After you sit and do all the comparing, size, comfort, capability, looks, dealer, add-ons, etc, there will be/are doubts as to which machine is right for you. That is the time to start listening to what your heart is saying because that will determine if you have any regrets after the purchase. If you want a backhoe, get it now because if you don't, you will wish you did when you had the easy choice. Money is usually what keeps most people from getting what they really, really want, whether they truly need it or not. Your tractor could outlast 2-3 new cars and still be doing everything you need it to do. The words would-have, could-have, should-have, do not need to be in your vocabulary after buying a tractor.
/ kubota vs. Kioti? #169
Well said.
/ kubota vs. Kioti? #170
I don't think you can make a bad choice between the two. I bought the Kioti, but could have been just as happy with a Kubota, although my wallet would have been a little thinner with the Kubota. Buy the one you really want.
/ kubota vs. Kioti? #172
I was talking with a guy and he said to go with a Kubota because ect ect ect lol. He mentioned the front axle on the Kubota's were (if I can remember what he called them lol) universal joints mabe??? Don't know the correct terms haha. He said make sure I get a tractor that has the same as Kubota. Are the Kubota's and the Kioti's the same when it comes to the front axle type, style?
Also when I was testing the Kioti the dealer showed me that the front loader had the float (rides along the ground I guess??). He pushed the loader handle forward and it went right to just above the ground.mwhen I was testing the Kubota I asked the dealer if it had the float also and he said yes but when I pushed the loader handle forward it wasn't like the Kioti and I don't really know what I'm doing and the was about four inches of know on the ground do I'm not sure if the bucket was riding just above the ground. So my question is does the Kubota have the float with the front end loader?
/ kubota vs. Kioti? #173
Both the Kubota & Kioti are going to have the same float. When you push the valve into float, it dumps both ends of the lift cylinders to tank. The loader arms will drop until something is on the ground. Depending on how the bucket is tipped or the brackets on the back of the bucket, it may look a little different, but functionality will be 98% the same. All float does is removes the ability of the main lift cylinders to support any kind of weight. The weight of the arms, bucket & whatever is in the bucket will push the arms down. Handy for parking the tractor so things don't get ugly if a hose breaks (the whole arm would come crashing down) and for back dragging to smooth or finish some ground.
/ kubota vs. Kioti? #174
We are selling our home and will be buying a new home with more land. I will be burning wood so I will need a tractor to handle full logs. Not sure what we will buy for a new home but it won't be anything under 10 acres and hopefully mostly wooded. The tractor will be used for everything I can use it for that I won't have to physically do. Really I should wait until we buy a new home BUT I want to buy now before I don't have the option not to go with the new emissions tractors.
/ kubota vs. Kioti? #175
Yes it has float
Sent from my iPad using TractorByNet
/ kubota vs. Kioti? #176
There is a difference in the Kubota and Kioti float. Not much and not very important, but a difference. If you have the lift up and push the Kubota into float, you will hear a hissing sound and the Kubota lift will come down at a slower rate than the Kioti. The Kioti will not hiss and the lift will drop rapidly. They will both contact the ground with a pressure relative to whatever the arms/cylinders SSQA and bucket or other implement weighs. Very handy for backdragging and smoothing materiel and other uses. The bucket will "float" up over most obstruction, like a rock for instance unless you are careless and set the angle too steep or it is just too high. Sales people will often say darn near anything to make a sale so his children can eat that night. Take anything most sales guys say with a large dose of ...well whatever.:laughing:
James K0UA
/ kubota vs. Kioti? #177
I trust uou are referring to "sales guys" but not to a "sales engineer", right? Haha
/ kubota vs. Kioti? #178
Outside of mowers, I have only owned Kubota tractors. I bought a B 5200 back in 1984 and now own 3 Kubotas two BXs and and an L. Never heard of Kioti but after reading this thread I will have a look at them. Resale of the Kubota is quite good. I sold my B 5200 for more than I paid for it, although in current dollars. Will the Kioti hold that kind of value? If so, it seems a good deal given what I have read in terms of the premium Kubota charges for similar performance/features.
/ kubota vs. Kioti? #179
Interesting, I didn't think you could drop it into the float position and it will come down slower.
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
1993 Ford LS9000 Truck (A61573)
1993 Ford LS9000...
Deutz F5L912 5 Cylinder Power Unit (A62183)
Deutz F5L912 5...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
Case-IH 9170 (A62180)
2001 Chevrolet 2500 Service Truck (A63116)
2001 Chevrolet...
