Kubota Quick Coupler
/ Kubota Quick Coupler #31
Yes Jim, as I suspected. And there are not spec/diagrams of the parts with measurements, so your help is invaluable. Thank you.
Yes 7 inches on center.
/ Kubota Quick Coupler #32
Jim, I have an LA352 Loader. And without a parts match, the arms are 39 inches wide, center to center, with 1" pins, 7 inches apart, and the U-mount on the bucket is 2 5/8 inches wide. It's my feeling that pretty much any part for a smaller unit with the correct pin spacing could be used by lengthening or shortening the crossbar.
Thanks!
Hi Steve, I just had a chance to go out and take some measurements. I actually have the old 54" pin on bucket still around so I was able to get the pin spacing and bracket dimensions directly from that.
The pins are 7 inches apart center to center.
Looking at the U-bracket from the top - the ID is 2 7/16" wide and the OD is just shy of 3 inches ( the brackets are 1/4" thick metal)
The arms on the LA504 are about 29 1/2 wide center to center.
So it looks like your main sticking point might be the width of the bracket itself - is that 2 5/8 " dimension an OD or an ID? Is it possible to take a picture?
Just for reference - the width of your loader arms at 39 inches - fits within the envelope of an SSQA - so it would likely be possible to engineer an SSQA to fit on your tractor. If that's a route you're thinking of going , let me know - I have SSQA bracketry around and it would be an interesting project to work out.
Another dimension to check - would be the actual width of the FEL arms - and the rod end of the hydraulic cylinder on the FEL - that would help determine whether they would fit within the width of the pin-on QA intended for the LA504
2020 MACK P164T (A60736)
2020 MACK P164T...
2016 KENWORTH T880 TRI-AXLE DUMP TRUCK (A62130)
2016 KENWORTH T880...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
2020 John Deere 26G (A60462)
2020 John Deere...
MMS 800 Remote Control Lawn Mower (A60463)
MMS 800 Remote...
2022 Caterpillar 289D3 (A60462)
2022 Caterpillar...
