Kubota PTO Powered Bagger for BX
   / Kubota PTO Powered Bagger for BX #1
walker450
Platinum Member
OK
M5040, BX25D, F2880, ZD1211, GR2120, KX-040-4
I bought a used GCK60-23BX grass catcher aka bagger for my BX25D. I have now learned that the 23BX means it is frame mounted amd the 26BX model is 3 point mounted. I didn't realize there was an option I assumed it was just a change they made at some point and depending on what year you bought it would be one or the other.
The GCK60-23BX will mount to the backhoe frame with the help of an adapter kit BX3086, but I was able to use some PVC conduit and make my own bushings to get me by until I order the actual kit. If you have a normal BX there are included mounts that bolt to the side of the tractor frame. If anyone wants more detailed pictures I can take them.
I forgot to ask to look at the mower deck and get the hardware off of the previous owners so I welded up one to get me by. They are 4 hours away so not sure if I'm going to ask them mail the pieces.... Also I am missing the deck baffle but will likely build my own.
I've only used it enough for two full loads and so far it is great. I have used a cyclone rake for the last 2 or 3 years but I rather have a PTO powered fan vs a separate engine. The Cyclone rake did work very very well and the capacity is very nice. If anyone has questions let me know.
   / Kubota PTO Powered Bagger for BX #2
I had a BX22 with the bagger and it mounted to the 3PH... It was a pita.. It did work very well but I always hated taking it off and putting it on. I always thought it should have just had a horizontal bar that sat in the hook area where the BH sat, Then be able to push it forward and slide a pin through the spot where the top link attached to the tractor.
Okay that's good news then, this one connects just like the backhoe but you also connect the top link. It was very akward the first time at least, but is very sturdy and is nice and close to the machine so the weight balance feels fine.
   / Kubota PTO Powered Bagger for BX #4
I also just recently picked up a GCK60-23BX for my Bx2680. I will say i prefer the frame mounted version, and once I get my hyd top link it will be very easy to r&r.
Mine came with all the deck mounting hardware, but unfortunately it must have been for a different size and model deck as it doesn't fit.
I also have to remake the deck baffle since it is pretty rough and doesn't mount up to my deck. I thought about just buying one but they are pretty spendy!
You've got that right! I have the metal and tools so I plan on just building everything to mount it. I'll take a few pics and share. I also plan on making a video attaching it and removing it.
The hydraulic top link would definitely be nice! I used a motorcycle jack and a floor jack in combination to mount mine but it was still quite a dance to line it up, it is nit balanced so trys to fall to the right side the whole time.
   / Kubota PTO Powered Bagger for BX #6
How many stands does yours have? Mine had 2, one under the blower and one on the bagger upright closest to the blower.
I moved that one to the further upright from the blower, and it seems to be fairly balanced.
I will say you do have to watch how you move it or else it will end up upside down quick.
Mine has two stands as well, I wasn't real sure where to set them, tried diff positions but ended up just using the jacks. I'll slow down and use a little more patience next time, I was just anxious to try it out!
   / Kubota PTO Powered Bagger for BX #8
How expensive are these things, as compared to say a cyclone rake. I saw one set up like this on a bad boy commercial zt at the dealer. But its a $22,000 lawn mower.
   / Kubota PTO Powered Bagger for BX #9
No idea new, I got mine used for 500.
I know the hard clamshell style I have on my zd331 was over 5k new.
   / Kubota PTO Powered Bagger for BX #10
Just looked on build my kubota.
MSRP was just over $2400
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
2015 CATERPILLAR 259D SKID STEER (A52708)
2015 CATERPILLAR...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2017 Ford F-550 Duralift DTAX39 39ft Insulated Bucket Truck (A55973)
2017 Ford F-550...
